Archos 605 flickering screen
nik_h
Hi all
posting again.....ive sorted out my mp3 files but now ive noticed a slight flickering on the screen (very minor) is this normal and do they always take soooooooo long to charge ???
Cheers in advance
Praxidike
Not sure about the flickering screen, sounds a bit iffy.
To charge, I guess you're using USB? They were a bit cheap with that and it does take forever to charge using USB, to try and get you to buy a dock that you can plug into the mains, and it's much quicker.
(By the way, there's an Archos sub forum here.)
nik_h
flickering sorted...it does it if you leave the mini dock in the machine but have unplugged it from the mains,once you remove the dock or plug in it stops the flickering,and thanks for the linky to the owners forum:smashin:
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
