Archos 5g not allowing Flash 9 code
Discussion in 'Video Streaming Boxes & Services' started by Zebadee69, Jun 14, 2009.
  1. Zebadee69
    Zebadee69
    Oct 17, 2001
    1,687
    Devon
    +42
    anyone else had this problem? My Archos 5g doesn't allow Flash 9 code, all that comes up is the Flash 9 symbol. It states that it does allow the latest flash programs but I'm having no luck. The unit has been updated to the latest firmware.
    Any help appreciated.
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    The problem is with Adobe rather than Archos, the version of Flash that Adobe offers for embedded devices supports some but not all aspects of Flash 9.
    Google for FlashLite and it will be a bit clearer.
    There is a new version on the way from Adobe but no idea when it will be available to Archos and then available to us.
    Just in case, 'no' it is not possible to update the Flash version from Adobe, only from Archos.
    Only thing that is worth trying is a full shut down and restart on the Archos as very occasionally some Flash files that should work do not, but a full shut down usually fixes that.
  3. Zebadee69
    Zebadee69
    Oct 17, 2001
    1,687
    Devon
    +42
    Cheers MT, that explains a lot, hope it's sorted soon.
