Archiving VHS tapes
Discussion in 'Blu-ray & DVD Players & Recorders' started by davidgirecourt, Jan 5, 2004.
  1. davidgirecourt
    davidgirecourt
    Hi all
    My good old VCR is going south and I've decided to go down the "digital way". I know need to archive my vhs movies onto dvds. Problem is that they are protected and I cannot copy them with my computer because it says so. Does anyone knows where I stand legally and/or have you got any technical insight?
    Thanks in advance
  2. dude1971
    dude1971
    There is a way around it, you have to snip one of the cables on your scart lead but I can't remember which one! It's illegal to copy the shop bought videos even if it's for your own use.
    If you are copying them onto a PC you can by software that will get round copyright protection though.
    Regards
    Dude
  3. davidgirecourt
    davidgirecourt
    Right
    I suppose it is easier to copy onto a computer and burn it back onto a dvd once the protection has been removed. I am about to buy a dvd recorder but this is my next headache.
    Thanks Dude
  4. applevenus
    applevenus
    Legally you can't/shouldn't.
    That hasn't stopped thousands of people doing it though....
    The problem you're encountering is Macrovision.
    There are devices available that defeat this mechanism. Do a search on these forums for some recommendations. The device sits "in-line" between your VCR and the recording device.
    Macrovision also affects DVDs - some players can be modified to defeat it though.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    If you like the movies that much why not just purchase them on DVD where they will be better quality anyway?
    Or aren't they available on DVD yet?
  6. davidgirecourt
    davidgirecourt
    I am trying to find a hack first.
  7. andip1967
    andip1967
    Dec 14, 2003
    24
  8. davidgirecourt
    davidgirecourt
    Thanks, i'll have a look at that.
  9. yatesd2404
    yatesd2404
    I've mentioned this before, am still unsure why it worked but I managed to backup my old Star Wars trilogy from VHS and the complete Young Ones series' to my Pana HS2 without any need for a change in cabling or consideration of Macrovision.
    Just thought I would add this as maybe it is worth trying before spending money on a Macrovision beater.
    Will also say for the record the only reason I have done this is that they are either not available on DVD yet or DVD versions have been cut because of copyright issues.
    Personally I don't see why it is illegal anyway, as I am backing up original copies I have purchased onto a different media for my own use - but that is probs for a different thread.
    Cheers,
    Dave.
  10. davidgirecourt
    davidgirecourt
    Yeah I know
    I am still looking and will let people know if/when I find a way.
    Thanks for the info.
  11. chilpillphil
    chilpillphil
    ive decided to go
    normal dvd player and sky plus,
    leave all the dvd reocoder stuff for another couple of years
  12. overkill
    overkill
    Nov 6, 2003
    11,842
    Murkeyside
    +1,205
    "Legally you can't/shouldn't". Is that the same as Music and software can't? The Music industry, after recent US rulings has been (deservedly) dealt a blow in that for backup purposes you can make ONE copy. This brings it in line with Sofware. I checked the latter with trading standards, plus a Microsoftie "person" & it is NOT illegal to make one backup copy of software. It is illegal to make multiple copies however..................
    There's also a scart cable that can stop Macromassiveprofitprotect.
