Archiving from V+ box - recommended hardware
mark*w
I've had my V+ box for over a year now, and I'd like to archive some TV shows off of it. So I am now looking for a new piece of kit to record the programs onto.
I understand that for the best quality I'll have to use the RGB Scart connection. So can someone recommend either a DVD recorder, computer TV card (laptop would be best) or other media recorder to copy the TV programs onto.
Mark
mark*w
Thanks for the quick reply.
But won't I have to use the component output from the V+ box, and doesn't that give you problems?
Ben
You'd only have to use component for archivings. You can use HDMI or whatever connection you normally use for everything else. The only content that won't play through component is some of the HDCP enabled HD VoD stuff, but then that wouldn't play through RGB scart either :)
Boostrail
Whilst Bens suggestion is very interesting as far as I can see this is effectively an HD capture device for a PC. I aso think it is perhaps a bit overkill for the OP's requirements.
He would be better off with a simple capture card or USB Device for his PC or a Sony or Panasonic HDD DVDR which is what I use. You can then copy recordings to the HDD from the V+ without interfering with your normal watching/ recording use of the V+. You can then drop these onto a DVD at your leisure. I use a RGB Scart connection to the DVDR which for playback upscales via an HDMI connection to the TV.
Passingbat
I hope I'm wrong on this one, but I thought the V+ VCR scart only produced a composite signal. I thought the only way to get RGB is to feed the TV scart into the HDD recorder and then to the TV, but then you wouldn't be able to use an HDMI connection to the TV from the V+ as you can't have TV scart output and HDMI output at the same time.
I have the V+ HDMI going to the TV and use the VCR scart to a Panasonic HDD and use the 'Copy to VCR/DVD' function in the V+ EXTRAS section. As far as I know, this gives me a composite signal.
Ben
I'm afraid you're correct in your assumptions. Boostrail's talking about daisychaining the V+ through his DVDR. So his V+ is in SD mode & connected via RGB scart to his DVDR. His DVDR is then upscaling the incoming RGB signal & outputting it over it's own HDMI connection to his TV.
Hope that clears things up :)
Boostrail
No it does not! It defo gives you a RGB signal if your HDD DVDR can accept this on its Scart input I have a Sony (made by Pioneer) HDD DVDR and what I get out of the VCR Scart from the V+ is categorically RGB.
Boostrail
No it B****y doesn't
Please read what I said!
What do you mean my V+ is in SD Mode? Its in 1080i via HDMI! So SD is upscaled to 1080i and BBC and VOD HD is presented at 1080i
Meanwhile the V+ "VCR" scart is connected at RGB to my HDD DVDR and this is connected to the TV via HDMI also but this is not "daisy chaining"!!!
I use the VCR scart only to download recordings to the HDD DVDR (or to watch a recording on another TV whilst another V+channel is being watched on the main TV whilst 2 other recordings are being made - brilliant!)
Ben
Chiiiiillll Winston :D
I assumed you meant "playback" on the V+, apologies if that wasn't the case.
In that case, excellent news. I guess there must've been a recent update or something-?
