Arcam's future plans?
Discussion in 'Arcam Owners' Forum' started by kirkj, Jun 10, 2004.
Tags:
  1. kirkj
    kirkj
    A hard question to answer, but does anyone know if the DV79 will be upgradable to support formats like Windows Media 9 HD, which is coming out in other players in the next few months?
    I'm in the market for a HDMI/DVI player, but don't want to spend too much on one that will be obsolete even before the year is finished.
    I doubt I can get an answer, but does anyone else have thoughts on this?
    - Kirk.
  2. crion
    crion
    Jun 6, 2004
    23
    I think by definition the DV-7x players will not be hardware upgradable, therefore the low price. Only the DV8x and DV2x have been stated to support future upgrades.
  3. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    Think your a little confused the DV-79 is not cheap unless you think a grand is cheap. I have just ordered the DV-79 from Sevenoaks and would be interested in stuff like future support for WMHD9 too.
  4. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    The DV79 is not upgradable.
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    But is it feasible to reason the DV79 already has the hardware support for WMHD9, and all it needs is a sw/fw update to enable it? I don't know, just speculating.
  6. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    WMHD9 will probably only be available on the new high def discs under development (thats if it takes off at all), such as hi def DVD and blue ray which the DV79 will not be able to play. This coupled with the fact that the DV79 has been designed to be a non upgradable player make it fairly irrelivant to speculate if it is possible to do it.
