@Peter Parker
Do I need to put any rockwool in the void between the backwall and the baffle wall?
I'm guessing if I build the baffle wall correctly then no sound waves should be able to get in this area and I'll only need to put some foam on the front of the baffle wall to stop reflection off the speakers with the screen up etc?
Many thanks
@Arcam_boy that's a really good question as it has also gone around in my head also !
This is
my understanding of the situation. War And Peace coming ...
You create a baffle wall by essentially having the face of the speaker drivers inline with a false wall you construct. This wall needs to be non-flexing and solid. As such two or three layers of different materials. The different materials so they do not resonate at the same frequency. This needs to be made as solid as you can. Overlapped materials and screwed.
However, as you have now created a large void behind where these speakers are, why not then go ahead and take advantage of this space by turning it into a base trap by filling it with 'stuff', prob. Rockwool. Which makes sense, but i messy.
Equally, if you're making a solid wall with two or three layers of, let's say, plasterboard ( dense ), ply and perhaps MDF. Is stuffing the rear really any use ? My gut feeling is, perhaps. Look at the inside of speakers, they are usually lined with insulation. So, it's kinda the same as doing that I think.
I've seen a lot of baffle walls where holes have been drilled into the 'solid structure' and this allows some of the sound to pass through and get 'trapped'. Which makes sense. I think this would work but you must ensure the baffle wall is really rigid.
The final thing I've noticed is where, on top of the rigid baffle wall more insulation is placed to reduce the effect of sound bouncing back off the AT screen.
What am I going to do in this situation ( as I'm using the same as you ).
1. Construct Baffle wall out of two or three layers of 'stuff' probable a mix of plasterboard and ply. Depends what I can get second hand a decent price ( seeing as new ply is £40 a sheet ). Perhaps Shuttering ply as that should be down around £25 a sheet.
2. I will back fill with Rockwool or similar. I've just found a place not too far away from me selling RWA45 at a pretty darn good price. Two reasons. One, to reduce noise coming into the room. Two, if it helps then the front wall is a large area that is not seen that allows me to chuck a load of sound absorbing materials.
3. I also have 4 purpose built subs I am installing in the wall, these I will build in 'tight' so I have no ability to perhaps twist a little ( as I might want to with LCR to get the 5% gradient to MLP ).
4. Drilling holes to assist the baffle wall do it's thing. Ok, look at all the sound defusors / absorbors that are custom made, they have gaps / slits / holes. Brains greater than mind have decided this works. As I know where all the vertical / horizontal structural timbers are for my baffle wall, I can put these in later, when I am convinced of it. I will have to ensure they are aligned ect. I have also seen, where people have done this they have had black material behind the baffle wall infront of the insulation, so in the hole it looks black.
5. The absorption material ON the baffle wall also makes sense. I need to research this a little more, however quite a few people have opted for the black foam egg cup stuff. Simple. Helps absorb / diffuse. And most of these people are brighter than me ... Oh and you can buy it in the colour black !
Hope my thoughts help or perhaps help cement your thoughts ?
