arcam vs cyrus
Discussion in 'Hi-Fi Stereo Systems & Separates' started by dood, Sep 25, 2003.
Tags:
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I currently have denon 3300 AV receiver used as a processor with cyrus straightline and XPA amps which bi-wire my kef Q55.2 fronts.
    I am considering changing the cyruses for an arcam delta 290, about the same vintage. The main advantages are that the arcam is remote controllable, and has processor input (convenient when switching from CD to AV and back).
    My concerns are will there be a degradation in quality (no longer bi-amped) and will the power handling be OK (cyruses are 50 W per channel each vs arcams 75 W)
    Off course I need to listen but I thought your comments would be helpful.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I think you will notice a difference in tonal balance(to my ears,the Arcams sound "drier" than Cyrus amps which tend to have a warmer sound)but I also think you may find the extra power useful...this should easily offset the lack of biamping,as you can still biwire.
    Many of us,myself included,don't think biamping is really worth it unless you're using an active system,or the power amps you have are run sufficiently near their limits to make it a good idea.
    Biwiring also is a contentious issue,with some speakers benefiting immensely,and others not at all.....you'd have to try that one.
