Finach2008
Is it possible to use the arcam solo neo as a pre amp with either an arcam a28 or aracm a38 thanks in advance
It's a more logical option, but whether it's a better option really depends on the rest of your setup. You may very well be optimizing something that isn't actually your problem (a "Porsche engine in a VW Beetle").Would the p38 be a better option
Given this information: Yes, the P38 is a better option.I am trying to put a Bit more power through my b&w cm8s as the solo neo doesn't seem to have enough power for them
