Arcam Solo & Ipod Lock Up
Discussion in 'Hi-Fi Stereo Systems & Separates' started by bradm, Aug 28, 2006.
Tags:
  1. bradm
    bradm
    When I use my rLead on my Solo and shuffle through the track list on my 30gb video ipod or try and play a track my solo locks up and has to be re-booted. It seems as though this bleeds my Ipod battery too. This is very weird. Any ideas. I do not know how to check my firmware/software version - so any help with that appreciated - but it was ceretainly up to date for use with the rLead (at least 2.1) and my Ipod mini works fine. Grrrrrrrr. Brad.
  2. bradm
    bradm
    Okay, I have read the sticky and I have f/w 2.1. I'll get it updated to 2.2 but that can't be the reason can it? Brad.
  3. webhammer
    webhammer
    Jul 6, 2006
    228
    28
    Indianapolis
    +22
    Hi Brad;
    I work for USA Arcam importer/distributor Audiophile Systems LTD. and I asked my customer service manager about this. He said that he has noted some kind of problem when the ipod has 200 or more track listings on it. Don't know if the cause for the lock-up or solution has been determined yet for it, sorry, he had no more info.
