arcam software downloads here
Discussion in 'Blu-ray & DVD Players & Recorders' started by WILDCAT, Jan 10, 2002.
Tags:
  1. WILDCAT
    WILDCAT
  2. damieng
    damieng
    May 7, 2001
    16
    Guernsey
    The software no longer appears to be available at that URL.
    I have added the software to my FAQ for the DV88 at:
    http://www.envytech.co.uk/dv88
    Although it will be removed if Arcam request it.
    [)amien
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    Morning...
    I have had the 1.76 upgrade installed by my dealer (after a lot of prodding to get them to get the CD's in ).
    All is good...you can power the player from the load button, and my sony remote now works as it should.. hoorah..
    Please could someone explain what the pass plunge option is for??
    I reckon Arcam should have a page on their website with a list of the updates and what they provide.. otherwise unless you find out about it here you could be none the wiser (hell I only found out about the 1.76 update from Retro... not one word on the Arcam site.. and my dealer never has a clue...)
    cheers
    Matt
  4. CWB
    CWB
    Dec 2, 2001
    102
    16
    Camberley
    A Pluge test allows you to set up your display (contrast, brightness etc). There is one on the Video essentials disc too.
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    Still confused then...
    In the DV88 options screen it has this option and you either set it or normal (can't remember the specific wording).
    What happens then.. I do not remeber seeing any difference anywhere when I turned it on ?
    matt
