Question Arcam power amp kettle lead advice
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Killak, Aug 2, 2018.
  1. Killak
    Killak
    Nov 27, 2015
    422
    London
    +56
    Hello
    I removed all my av equipment to redecorate my room. Putting everything back now and I seem to have mixed up or lost the original power lead for my Arcam P7 power amp.
    I do have other kettle cables, can I just use those or should I try and source an original replacement cable from Arcam.
    I tried doing a bit of research, and there's alot of talk about upgrading to "special" power cables. I was quite happy with the original ones performance and just want the same again but don't want to damage the amp by putting any old cable in.
    Any advice would be much appreciated...
  2. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,068
    Zurich, CH
    +1,551
    Any 13A (i.e. fused at 13 Amp) kettle lead will be fine and you can happily use "any old 13A cable" and achieve identical measurable performance.
  3. Killak
    Killak
    Nov 27, 2015
    422
    London
    +56
    Ah thank you good sir!
  4. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
  5. Killak
    Killak
    Nov 27, 2015
    422
    London
    +56
    Oh of course... the £150 super burn in is a no brainer!
    May get a 2nd one for the toaster...:D
  6. larkone
    larkone
    Apr 21, 2006
    4,390
    134
    North Essex
    +1,260
    Then your toast will pop out already buttered and with your favourite spread already applied
  7. Rock Danger
    Rock Danger
    Oct 10, 2007
    11,421
    2
    Belfast - Northern Ireland
    +5,187
    I made another one today for £8 in parts. It's rhodium and cryo.
    I haven't run it in yet of course.
