Arcam P75+ and P75
Discussion in 'AV Receivers & Amplifiers' started by Hawklord, Sep 26, 2003.
Tags:
  1. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
    I was wondering what the difference was between these two (if any). I've noticed the P75 going for around £200 and the P75+ for £260. Is the + worth the extra £60 and is this a bargain or is it worth saving up a bit extra for the p85+. I'll be using the power amp coupled with my A75+ to bi-amp my linn ninka's. Would the A75+ and P85+ be a good match or am I better off going A75+ and P75+?
    Also is it possible to have an extra channel fitted to the p75/85+ since my ninkas have 3 drivers? Would I be better off looking for an alternative to Arcam?
    decisions decisions. :rotfl:
    thanks for any pointers
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    +286
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    +286
    anyone:blush:
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    The P75 and P75 Plus have similar technical specs but the 75 Plus definitely sounds better - about 20 component changes / additions make the difference. I would go for the 75 Plus.
    Having said that, the P80 is better again (retail £420) and the P85 is a bit better than that (retail £530). You pays your money and takes your choice, as they say :)
    If you want to triamp your speakers you can do that at any time as the amplifiers can be daisy chained.
    HTH.
    John Dawson (Arcam)
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    +286
    thankyou
