Arcam multi-region hack reliable??
Discussion in 'Arcam Owners' Forum' started by MrNPG, Sep 12, 2005.
Tags:
  1. MrNPG
    MrNPG
    Apr 13, 2005
    778
    Poole, Dorset
    +63
    Hi folks,
    I am on the verge of getting an Arcam DV78 DVD player and need to know just how "reliable" the multi-region remote hack is.
    All my previous DVD players have been modified by the dealer as they were not "remote hackable" therefore I have never had a player before that can be remote hacked.
    Is the Arcam hack 100% reliable? Multi-region playability is crucial for me so I don't want to buy a player that then has multi-region playability problems.
    Cheers.
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    Worked great on my DV79 dude :thumbsup:
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    One of, if not the best
  4. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    Are they not multiregion as standard now? My 89 came multiregion. Seems to work fine.
  5. Timmy C
    Timmy C
    Oct 10, 2003
    5,211
    +409
    Never had a problem with my 27A with region 1, 2 or 4 but never tried anything else.
  6. Hifi addict
    Hifi addict
    all the arcam DVD players are multiregion. Hack is VERY simple and 100% working. I have tried all regions on my DV79 (huray to ebay) and they all play fine.
  7. MrNPG
    MrNPG
    Apr 13, 2005
    778
    Poole, Dorset
    +63
    Cheers guys :)
  8. Janibrewski
    Janibrewski
    Sep 17, 2005
    13
    I just bought an AVR300 and DV79 - I'm in the U.S. Can someone explain to me the "hack"? I would love to be able to play DVD's from Japan.
    Thank you!
  9. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Hi and welcome to the site :hiya:
    Cannot remember which one it is but give one of these a try.
    Open the disk tray
    Then press
    3
    Close the disk tray
    switch if off and then on again and it should be region free
    And heres another:
    Do this: stop, setup, 4, 7, 9, 2
    This takes you into the service menu where you can adjust region settings.
    Hope this helps :)
  10. MrNPG
    MrNPG
    Apr 13, 2005
    778
    Poole, Dorset
    +63
    I got my DV78 last week and confirm that the following hack worked (so far!) perfectly;
    open tray, enter 1 1 1 1 and then 1 3, then close the tray. Hey presto! multi-region player!
  11. Janibrewski
    Janibrewski
    Sep 17, 2005
    13
    Woo hoo!!!
    I'll try it when I get my player next week.
    Thank you!
  12. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    AFAIK Arcam supply the same machines all over the world with the same software to change the region, so it should be fairly full proof. It's worked for me and I've had region 1, 2 and 4 on it without an issue :)
    Andy
  13. chillijoe
    chillijoe
    Jun 30, 2008
    41
    11
    Shoeburyness
    +3
    I have just bought an Arcam DV89 and i'm afraid the hacks you have described do not work for my machine. The audio works but no picture just an 'invalid region' notice comes up on my TV. Strange as others have said it works perfectly!
    Any ideas?
    Chilli
  14. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    9,859
    Zurich, CH
    +1,495
    Keep trying. Probably you're pausing or hesitating. Power on, open tray, 111113.
  15. fabfour
    fabfour
    Aug 10, 2005
    102
    +4
    My Arcam player will even play R1 discs with RCE. Never had an issue with any disc.
  16. Naimer
    Naimer
    Jan 17, 2006
    58
    USA
    +16
    100% reliable for me on a number of different Arcam DVD players through the years...
  17. 666monkeyboy
    666monkeyboy
    Jun 2, 2009
    Work's a treat; have recently made my DV139 multi-regional(following the above instructions). So far no issues trying to play Region 1, 2, 3 and 4 coded DVDs.
