Arcam fMj DV27 / DV88 and SDI
Discussion in 'Projectors, Screens & Video Processors' started by ReTrO, Mar 31, 2002.
Tags:
  1. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Does anone know of an SDI mod for the Arcam DV88 or fMj DV27?
  2. Jenz
    Jenz
    We wish.
    If only we knew where to solder the SDI outputs...
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    I suppose it'd be a case of hit and hope with the internal digital video link I suppose if anyone had a go.
    If only I had some way of testing for an SDI output...
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
  5. BruceG
    BruceG
    Jan 4, 2002
    9
    Bedfordshire, UK
    Yes Gordon, it probably is worth chasing up. What did you have in mind? S'pose it's another reason to get a Vigatec with an SDI input then?
    Cheers,
    Bruce
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    I just wondered. Neil, Rick, Myself and you...is that enough? The mod kits for SDI are not cheap. Installing them is not easy and before that expense I need to get someone to work out how to do it. This would mean StereoStereo probably loosing a dem DV88 for a while. I think we may know someone up to the task.....
    I'll have a chat with "the powers" and see if this is possible/feasible.
    Gordon
  7. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    dont want to sound thick but what is sdi?:confused:
    also any of u guys know if theres a vga out upgrade planned/available for the dv88,ive got mine in for the prog/scan upgrade,should have it back next week:D ,
    so ill probably be pm'ing one of you for the pal codes/hack;)
    cheer carl
  8. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    hi all
    dosnt matter about explaining,just done a search on this and it went right over my head:eek:
    think ill stick to the basics:confused:
    cheers carl:D
  9. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Hi i have been wait ing for nearly 2 months for arcam to send progressive scan module to my dealer is there a shortage
    do i have to dump the arcam to get pro scan
    does the module exist ??
    [email protected]:confused: :confused: :confused:
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    It does exist.....every FMJ27 has one inside....wonder what the delay is...perhaps you could post a message for John Dawson and see what he says...
    Gordon
  11. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Patmyhead -
    As far as I am aware there is no major delay on the prog scan module. Please advise the name of the dealer through whom this was ordered (privately if you wish) and I will follow it up next week.
    John Dawson (Arcam)
  12. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Hi my dealer has just told me that i can have the upgrade fitted next week
    Is this coinciedence or what now all i have to do is find out how to make the arcam talk in PAL & get some leads made up
    [email protected] ;) ;) ;)
