Arcam FMJ CD 33 or DIVA CD 192 ?
Discussion in 'Arcam Owners' Forum' started by Yannis Koliavas, Aug 21, 2004.
Tags:
  1. Yannis Koliavas
    Yannis Koliavas
    I'm about to upgrade from my old Arcam Alpha 5 cd player.
    I'm considering one of these two players. I use valve amplification. I listen to ethnic, jazz, soft rock and a little bit of classical music.
    Has anyone auditioned or does own the aforementioned cd players?
    I 'd like to have your recommendations.
    Any opinion will be gladly accepted.
    Thanks! :)
  2. vistisen
    vistisen
    Jul 10, 2004
    83
    Silkeborg
    +3
    Hi, I have just upgraded from an Alpha 5 CD til a FMV CD23. The change is amazing. I was going to buy an Alpha 9 (Which is what I could buy here in Denmark) This is also a great player. But the cunning salesman, casually put my trial CD on an FMJ23 "just while I'll find the packaging sir". It took less then 10 seconds for me to decide that He could put the Alpha 9 box back where it came from.
    I have since upgraded my trusty AR Cambridge pre/power combo to an FMJ A25 and reused my old power amp to bi-amp my Kef 104's The result is that I now need to hear all my CD's again. :smashin:
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I have the CD33 and can honestly say it is stunning. The are a number of differences between the DiVA series CD192 and the FMJ CD33 most of them fairly subtle internal differences but the most obvious being the casework and build quality. Stereophile magazine just reviewed it recently, there is a link below.
    http://www.stereophile.com/digitalsourcereviews/704arcam/index.html
  4. Yannis Koliavas
    Yannis Koliavas
    Thanks for the info given!
    Yesterday I phoned an Arcam dealer and I was offered a CD 93 the predecessor model of CD 192 at a very competitive price. so, should i buy the CD93 or go up to CD33 ? Any opinions? Are there significant differences in sound quality between CD93 and CD33 ?
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    The differecne between the CD93 and the CD33 is night and day, get the CD33 you won't regret it.
  6. Yannis Koliavas
    Yannis Koliavas
    Today I finally purchased the FMJ CD33T cd player! :)
    Now it's on my rack, connected, spinning disc after disc to fully break in.
    I' m very happy!!! :thumbsup:
    The sound is balanced, soft and mature.Absolutely involving sound.
    Thnks alot guys!
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I told you that you would like it. Welcome to the club.
  8. Yannis Koliavas
    Yannis Koliavas
    Thanks! though I'm familiar with Arcam products. I have a Delta 290 integrated (purchased in 1993) and an Alpha 5 Cd player (purchased in 1994)still working after all these years. Now I use them as a second system in my office. :)
    I auditioned the CD33 with C30 pre and P1 monoblocks driving Audiovector M3 Avantgarde speakers. After one hour of listening I was sure about my choice!
