Arcam firmware update!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jimcarney, Mar 10, 2005.
Tags:
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Called in at my local dealer today to see if he had any firmware CDs!
    he said it would be better if I brought my DV79 in to have it installed ,he said I could void the warranty if I did it wrong ,is this the case ?......Jim
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,601
    Rainham Essex
    +2,543
    If you DIY and all goes well then there will be no probelm with your warranty. If however somethijng does go wrong then it will be a chargeable repair.
    I've just recently done my own upgrade on my DV29 with no problems, and TBH can't see what could go wrong other than a power cut at the wrong time. But it is your own risk if you do DIY.
    The other thing to say is, why do you want to upgrade the firmware? Are you having problems with the player or is it just a matter of wanting the latest? I was havijng problems with my player, which is why I did the upgrade. However there is now an even newer version and I see no reason to upgrade as everythijng is currently working.
    If it aint broke, don't fix it!!!
    Mark.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    I concur, if you do it yourself and cock it up (which I know is hard but it is possible) then it is not covered by warranty and you will be charged either by the dealer or by Arcam to fix it.
  4. GarySargent
    GarySargent
    Jan 19, 2005
    64
    +5
    If you are half competant with a computer I'd do it yourself. Watching the dealers scratch their heads when you say the word "firmware" does not instill confidence!!!
  5. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Why wouldnt it be covered by warranty ? I called Arcam they sent me the update disc - no persuasion required. Why would they send it to me directly if the warranty was an issue ?
  6. grey torq
    grey torq
    Jul 13, 2002
    394
    28
    +26
    Unless Arcam are content for you to return a dead unit to them for repair at no cost, which is something you should check with them first.
    Then your contract for purchase is with the dealer who has the right to decide the warranty conditions upon which he offers the goods to you. Hence if the unit is faulty or develops a fault he will help, but if you through incompetence turn a working unit into a dead one trying to upgrade the firmware, why should he help. The unit worked fine before you trashed it. If he makes it clear to you that all upgrades have to be done by him then he is taking the risk. If you do it yourself why should he still carry the risk?
  7. davehk
    davehk
    Oct 17, 2003
    713
    28
    London
    +45
    Actually, I believe the manufacturer's warranty is between the manufacturer and the end customer - the retailer acts as the maunfacturer's agent I think.
    The laws covering this are different from, and in addition to the normal consumer legislation that covers the contract between the retailer and his customer.
    So it's up to Arcam, not the retailer, to decide what the warranty covers.
    FW updates are discussed elsewhere in this forum, with replies from Arcam that show clearly that you do this at your own risk and if it goes wrong, the fix is not covered by warranty.
  8. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Thanks for the replies guys,what are the benifits of the latest firmware ?..Jim
  9. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Just got an AVR-300 yesterday. How do you find the firmware level?
  10. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Via the Arcam Importer :
    Press DVD & SAT buttons on the front Panel. It displays in the AVR300 and if a video device is connected also there in more complete form..
    My unit is Version 2.74. Looks like it is pre-historic. Comments from someone at ARCAM are welcome.
  11. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    I would suggest you ask your dealer to update it for you. Alternatively I can e-mail you a copy of the firmware but this is done entirely at your own risk and if you mes it up you will be charged by either your dealer or Arcam to fix it.
  12. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Thanks. I already got the software, instructions, etc. Asked the dealer to perform it, but they have no experience. ARCAM is in the process of switching importers here in Portugal. My unit came from the company which will cease to be an importer soon.
    I have no problems with the computer side of it, but I am afraid thar the ARCAM hangs in the process of loading and what can you do then. How many times did you perfom the operation? Where all sucessfull?.
  13. Jim_R
    Jim_R
    Where can I get a firmware CD in the USA?
  14. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Just did it myself. No problems at all. Seems to sound much better in DTSNeo music. I do not use center channel and think I never will. The Front speakers are driven by an A22 in proc mode and bi-wired. It is quite a superb kit for surround sound for those who have a large library of CD (85% classical, 15% Jazz) and do not want to buy the same thing again in SACD or DVD...
  15. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    How do I check which firmware my unit has ? thanks in advance ...Jim
  16. RacerChris
    RacerChris
    Doesn't Arcam publish what updates are available on the Internet and what the updates include?
  17. GarySargent
    GarySargent
    Jan 19, 2005
    64
    +5
    That would be far too sensible!
    And since they only recommend using dealers for upgrades, it would lead to dealers being swamped with requests for upgrades.
  18. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    In fact ARCAM publishes that. But you have to know the Internet address. This I will not supply, but I believe that if you ask nicely Mr. Andy Dutton, and are a knowledeable user of PC, he may supply that to you...
