Arcam DVD player hacks
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 22, 2005.
Tags:
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,925
    2
    167
    Birmingham, UK
    +9,660
    This hack works on the following Arcam players: FMJ-DV27, FMJ-DV88, HT-DV90
    * Press the Open/Close button on your Remote Control
    * Press the buttons 1, 1, 1 and then 1 one at at time from the Remote
    * Then press 01 on the Remote to select Region 1, or 02 for Region 2, and so on, or enter 13 to select Region Free
    * The word Region and then the number you selected should briefly appear on screen to confirm that the hack has been successful
  2. SL Boy
    SL Boy
    Mar 11, 2004
    36
    It also works on the DV 79
  3. Prith
    Prith
    Hi!
    I tried this on the DV 137, but it does not work. Also have connected an HDMI cable to a SONY BRAVIA LCD (HDMI to HDMI) I get the picture but no audio is coming. Can anyone help in coverting the DV 137 to region free & as to why I am not getting the HDMI Audio out.
    Thanks in advance
  4. colinfreeman
    colinfreeman
    Nov 21, 2008
    Hi - I would also like to know how to convert my DV137 to region free? If you get a responce to your original question can you ask this question to the respondent....assuming they are able to sort out your problem.
    Thanks!
    Col.
