Arcam DV89 audio output setting.
Discussion in 'Arcam Owners' Forum' started by Maninblack, Mar 29, 2005.
Tags:
  1. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    I have an Arcam DV 89 connected to a parasound C2 via digital coax for sound.
    In the ARcam 'Audio' setup, I can select.
    2 chanel PCM
    or
    2 Channel Bitstream, or
    6 channel bitstream.
    Is there a correct setting for listening to CD or DVD?
    2 Channel PCM seems bassier for cd listening and 6 channel bitstream has the correct 5.1 encoding, any ideas?
  2. mjn
    mjn
    May 24, 2001
    17,616
    Herts, England
    +4,540
    2 Channel PCM, means the DV89 is decoding to analogue, and bitstream means your amp is decoding to analogue.
  3. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    Thanks for that.
    Should I be using 2 or 6 bitstream?
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    You should have the DV89 set to 6ch bitsteam for DVD surround playback. When you play a CD it will automatically use 2 ch PCM.
    For best CD sound quality, usually, using the DAC in the DVD player will sound better. To do this connect a pair of analogue interconects to a spare input on your amp (CD would be ideal) then select the CD input instead of the DVD input when listening to CD. This way the amplifier will use the analogue output from the DVD player when playing CD and the 6 ch bitsteam output when playing DVD.
    Regards,
    Andrew
  5. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    I see what you are saying, but when I force the output the sound is different?.
  6. Greggles
    Greggles
    Mar 15, 2005
    1,067
    St. Saviour, Jersey
    +73
    I'm a bit confused. Do the above settings apply to the DV29 player. I was under the impression that the digital output was the same whether the player is set to Bitstream+2ch or Bitstream+6ch and only the analogue outputs are effected. The user guide (for the DV29) states that Bitstream+6ch should only be used when, either:
    you are using the multichannel analogue output to connect to your amplifier (eg for DVD Audio) , or you are using the HDMI output to carry multichannel uncompressed audio (to suitably equiped devices)
    Greg
  7. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    My appolagies you are correct, you should use the 2ch option not the 6ch one.
    Andrew
  8. mjn
    mjn
    May 24, 2001
    17,616
    Herts, England
    +4,540
    Yes, because when using bitstream, you're using the DACS in the amp, and when using PCM, you're using the DACS in the DVD player.
  9. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    All understood!
    Thanks for everyones input.
    Its now set as 2 channel bitstream and sound for CD's has improved.
    Is it possible films will be better now?
  10. mjn
    mjn
    May 24, 2001
    17,616
    Herts, England
    +4,540
    Only if you use the 5.1 output of the DVD player, into the 5.1 Ext inout of your amp.
    I'm not sure if the DV89 uses different DACS for CD and DVD's though. So you could try and see which you prefer.
  11. Greggles
    Greggles
    Mar 15, 2005
    1,067
    St. Saviour, Jersey
    +73
    Surely if the DVD player is set to Bitstream+2ch the player will down-convert the 5.1 channel analogue output to stereo. If you want to use this connection it must be set to Bitstream+6ch. Similarly, anyone who has inadvertently tried to play CDs through the two channel analogue output while the player is set to Bitstream+6ch will attest to how strange it sounds. The digital (bitstream) output is identical in both cases.
    After some experimentation, I have found that I prefer to use the dacs in the AV8 to those in the DV29 for CD replay.
    Greg
  12. mjn
    mjn
    May 24, 2001
    17,616
    Herts, England
    +4,540
    True, but why would you want to down convert 5.1 to stereo?
  13. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    I am wondering what I am listenting to then? I have a DV89 connected by co-axial digital to the digital input of my AVR300 and by analogue input to the CD input. The DV89 is set to 6ch bitstream so I always assumed that it was 6ch bitstream (when appropriate) via the digital input when I select DVD on the AVR300 and 2 ch analogue stero when I select the CD input?
    Surely you don't need to change the settings depending if you are watching a DVD or listening to a CD?
  14. Greggles
    Greggles
    Mar 15, 2005
    1,067
    St. Saviour, Jersey
    +73
    There seems to be some confusion here. the term "6 channel bitstream" should read "6 channel PLUS bitstream". The bitstream ie digital output is the same whether the 2 channel or 6 channel option is selected.
    The “2/6 Channel” part relates to the analogue output only. Therefore, if you are connecting the 5.1 analogue output of your DVD player to the appropriate inputs of the amp (ie for DVD audio/sacd), you would use the 6 channel option.
    For stereo (CD) replay, you should use the 2 channel option.
  15. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    So, does that mean I should use the 2ch Bitstream if I want to watch DVDs and I only listen to standard stereo CDs and not multi channel audio. This would give 2 ch analogue through the CD output and bitstream via the digital coax?
    Or do I need to change the output all the time between DVD and CD?
    Chris
  16. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    Yep, that's exactly the way to do it, it mean that any material you play will only be output as stereo from the analogue outputs but the digital output will still work as normal.
  17. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    Leave it to 2 unless you want to use the a full analog connectio (i.e. 6 rca's going to the mulitchannel input of reciever/pre). Otherwise for movies, you can use the digital coax connection which will always be multichannel if the source has it. If you are only use 2 channels for analog connection (i.e. CDs) there is no point in setting it to 6ch.
    So to summerise, coax to digitial input of amp assigned to 'DVD'. L+R to input of amp marked CD and setup to 2ch. When watching movies, just select DVD, and when listing to CDs, select CD (with stereo direct).
    I don't actually have DV79 or DV29
  18. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    this makes very interesting reading, so i should set mine to 2 channel bitstream untill i play a dvd-audio disc then i should switch back to 6 channel bitstream is this correct
  19. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    Thanks guys, all is now clear....I'd always had it set to 6ch bitstream as I assumed that was for the surround.
    Chris
