Arcam DV89 and DVD-A
Discussion in 'Blu-ray & DVD Players & Recorders' started by Merritt, Jul 2, 2004.
Tags:
  1. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Im looking at buying one of these (DV89) machines tomorrow and just have a quick question.
    I have my current dvd player connected to my AVC11SR amp via digital optical connection only. If I want to listen to DVD-A on the DV89, do I need any additional cables or will the digital optical link suffice?
    Steve
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,245
    2
    +3,769
    You'll need a 6 channel hook up for true DVD-A. Do you have any discs you want to listen to that much?
  3. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Nope - I don't currently have any discs but seeing as the 'feature' is there I thought I might try it... Is it worth spending some cash on the cables just for DVA? I assume Im still ok using digital optical for everything else?
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    There is absolutely no point in buying any DVD-A titles unless you plan to listen to the high resolution audio. You can also take it from that comment that it is worth doing and worth doing well. I currently have my DV89 hooked up to the multi channel inputs on my AX3 with three pairs of Black Rhodium Rhythm interconnects which I bleieve a a suitable mimimum level of cable inorder to hear the benefits of this source. Do be aware though that although there are a fairly large number of discs available not all of them are created equal. I currently have about 35 DVD-A titles and am fairly happy with most of them, if need any recommendations then let me know.
  5. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,207
    +1,190
    It's got to be worth a few cables given that your system has the functionality.
    I hope you've got a good price on the DV89. I'm picking one up for £599. PM if me if you need details (as I may not check here).
  6. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Crustyloafer - thanks for the comments & yes I am definitely interested in your DVD-A recommendations please!
    Triggaar - im hopefully picking it up today for £599 but thanks anyway. Actually you just got me thinking - I hope that includes VAT!
    Steve
  7. hi_robb
    hi_robb
    Lo there,
    DVD-a is well worth the extra 6 analogue cables. In all honesty once you start listening to good dvd-a you'll be hooked, it's as crisp as a packet of walkers.
    A couple of good dvd-a titles that I can recommend are
    The Eagles - Hell freezes over
    Norah Jones - Live in New orleans
    John Lennon - Best of (I Think)
    Queen - Greatest hits 1 + 2
    Al lthe above are really fantastic with the best of the sound going to the eagles album, it's a live album but tis probably 1 of the best live albums I've ever heard. All except Norah jones are in DTS.
    1 thing though if you do get the cables.
    You'll most likely need to turn the bass level on your AMP up to +10 to get the bass sounding good. On my Ax5 I have the sub set @ +10 for my multi channel inupts. If I set it any lower there bass is inaudible.
    It took me about a week to figure that one out. I was very disspointed at first as the top end was stunning but bass was nowhere to be heard. Once I had made my adjustments though I was in audio heaven.
    Oh and get good cables, for value for money and just damned good cables, try Mark Grants cables which you'll find in the powerbuys forum.
    I highly recommend then :)
    Davey
  8. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Surely apart from nora jones the others are music dvds not dvd-a, i have only got 5 dvd-a titles can recomend hotel california eagles, also tubular bells is quite good even though its not recorded at full resolution
  9. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    Just to make you aware hi-robb, nonoe of the titles you listed are actually DVD-A titles, they are Music DVD video titles with either Dolby Digital or DTS soundtracks on them. THe Queen ones you mentioned have a DTS 96/24 soundtrack which is higher resolution than most and it sounds great, however the fidelity of those still doesn't come close to the quality you get from proper DVD-Audio titles which have an MLP lossless compression soundtrack on them. If you or anybody else need to find out more about the DVD Audio format then the link below should help.
    DVD Audio FAQs
    There are a couple of website which review DVD-Audio titles, the links to them are below
    High Fidelity Review
    Audio Revolution
    My favourite discs so far are listed below:
    Flaming Lips: Yoshimi Battles The Pink Robots
    Eagles: Hotel California
    Fleetwood Mac: Rumours
    Eric Clapton & B.B. King: Riding With The King
    Steely Dan: Everything Must Go
    Donald Fagen: The Nightfly
    Steely Dan: Two Against Nature
    Joni Mitchell: Both Sides Now
    REM: Automatic For The People
    Randy Newman: Little Criminals
  10. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    also if you like yes fragile is quite good as is brain salad surgery by emerson lake & palmer
