arcam dv88 remote - problem with learning remotes
Discussion in 'Blu-ray & DVD Players & Recorders' started by Plump, Feb 24, 2002.
Tags:
  1. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    some learning remotes can not learn dv88 codes correctly?!!!
    when using them in dvd menu - i can move cursor only once to one direction (i am using cambridge audio learning remote) . it looks like part of the code is not transmitted or simmilar. i heard something about parity bits but have no idea what it is!!!
    can marantz pronto clone handle this
    can real pronto handle this
    cheers
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    When I had my DV88 my Pronto worked 100% with it.
    No problems here.
    Are you sure you have learned each command correctly?
    Might be worth while putting them in again, just to make sure.
  3. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    sure i did!
    it worked fine on arcam learning remote (borrowed for test), and on my main remote (TAG) but that one is in other floor!
    there must be some reason.
    but thanks anyway, my next investment is named pronto!
  4. damieng
    damieng
    May 7, 2001
    16
    Guernsey
    The trick is not not try to "learn" the codes from the Arcam remote but instead to use the RC-5 mode when programming the button using PC software.
    A full list of the codes can be found in my Arcam DV88/DV27 FAQ at http://www.envytech.co.uk/dv88 including those for a discrete on/off function (Player firmware 1.70 onwards).
    Note that the parity bit requirement has been removed from the latest 1.74 firmware.
    Regards,
    [)amien
  5. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    you probably mean 1.76 which is not officially released yet
    btw, i learned something about those remotes from your arcam dv88 site. cool one. congratulations! i'll still go for pronto soon, i like the concept.
    #how did you get that 1.76 ??
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    Over the Hill & Far Away
    +137
    Hello...
    1.76 is offically out.. I have had my DV88 upgraded at my dealer.. and now my sony universal remote works great....
    Matt
  7. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    HI i understand why you need a U RC the arcam is the worst remote i have ever used
    for a dvd player of this class the remote stinks
    pat:( :(
