arcam dv88 prog scan upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by Gliese 581c, Mar 1, 2003.
Tags:
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,750
    On AVForums
    +568
    Ive had the prog scan board fitted to my dv88....to be honest ive plugged up the component cables to one set of the component video out connections not thinking if i've actually got it plugged up to the correct set now there's 2 to choose from...
    Could someone please clarify which set of component out's should I be using ?
    thanks:smashin:
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    The interlaced Component outputs are the ones in a square configuration with the Composite output at the top left of the square (when facing you). Therefore the Progressive outputs are the other set :).
    [​IMG]
  3. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,750
    On AVForums
    +568
    whew....;)
    cheers m8
  4. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    well arcam whats it like is there a lot of difference with pro scan??
    by the way great football team you support pity we wont be getting into europe again!!!
    jason
