arcam dv88 prog/scan upgrade?
Discussion in 'Blu-ray & DVD Players & Recorders' started by codling, Feb 12, 2002.
Tags:
  1. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    hi all
    thinking of upgrading my player to prog/scan.(might be getting the new panny pj)
    will it be able to do pal progressive?
    hope so:)
    also how do i go about getting the upgrade.do i see the dealer where i bought it or contact aram themselves?
    tanks cod
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +346
    It will not do PAL progressive "out of the box", but there are plenty of people here that can tell you how to chance it so that it will.
    I guess you should contact your dealer.
    Cheers,
    Liam
  3. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    Any chance you got elaborate? The DV88 is one that I'm considering and will (eventually) feed a plasma screen so PS might improve the quality of picture. What's the difficulty with getting PAL progressive out of a DV88 other than the licencing issues?
    Regards
    Rob
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +346
    I don't have the details, but there are plenty of people on this forum that have DV88 or DV27 players - a private message to one of them should yield results.
    Nothing. It is purely a licensing thing.
    Cheers,
    Liam
  5. Lowrider
    Lowrider
    Rob,
    If you plan to get the upgrade, I recomend you get the FMJ DV27, it costs about the same as the DV88 plus upgrade, and it has better components and chassis, so better sound and image...
    I just replaced my DV88 for one, really a big improvement, even before I use progressive scan...
  6. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    lowrider,
    did you part,ex your dv88.i have been thinking of this.
    if so how much did they give you for it?
    thnks cod
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    codling: Which PDP are you thinking of getting? Some like the new Pioneers don't currently support PAL progressive (there'll be some way around it).
  8. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    retro,
    i dont really whant to change my dv88(only had it about 10 months) ,i really like it.
    95% of my dvds are r1 anyway,so only ntsc progressive would probably do me for now.if the arcams could do pal progressive
    ,it would tempt me to buy more r2.:)
    so fingers crossed that they come up with something.
    thanks cod
