RaceTripper
I just updated the SW in my DV88 Plus to 4.0.18.
I still have the same problem I had with v4.0.00. I was hoping 4.0.18 fixes it, but it doesn't.
Sometimes when I press the STATUS button the player goes into SETUP mode. This can be real annoying when playing a DVD, and it confuses the wife (who thinks she's then doing soemthing wrong).
I am not fat-fingering the remote either. I have a Home Theater Master MX-700 and have programmed it with the specific discrete codes (rather than by learning them from the original remote).
I have the problem with the original remote as well, but since the buttons are right next to each other I couldn't be sure I wasn't accidently pressing the SETUP button.
What's curious is that the discrete codes for these two functions are consecutive:
SETUP: 25-74
STATUS: 25-75
So maybe that has something to do with it.
Anyone else notice this?
Dean
SETUP: 25-74
STATUS: 25-75
Dean
