arcam dv88 picture help
Discussion in 'Blu-ray & DVD Players & Recorders' started by matmum, Jul 5, 2005.
Tags:
  1. matmum
    matmum
    Mar 23, 2003
    104
    16
    england
    hi
    i am having a bit of a problem setting up the black levels on my arcam dv88 dvd player so that pal and ntsc display the same.
    i am aware that pal is 0 ire and ntsc 7.5 ire - so what are the correct settings to use in the setup - do i need them both set to 0 ire?
    also below the black setup option there is below black - will i need to change that as well.
    i read somewhere that the arcam picture is better if manually selecting the regions, a review said the colours are more vibrant - is this something worth doing - or is there no difference.
    cheers :)
  2. Phil from 62
    Phil from 62
    Jun 14, 2005
    59
    Essex
    I don't know the answer...but you could try looking here.
    http://www.envytech.co.uk/arcamdvd/
    You can emeil the guy that runs the site too...he is very helpful.
    Failing that email tech Support at Arcam they are excellent.
    Good Luck!!
