Arcam DV88 owners: Please do a test for me
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Apr 20, 2001.
Tags:
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,186
    Born in Bristol but now in Newport, (for my sins)
    +733
    I am desperate to buy a DV88, but I am not going to spend a grand until I have had chance to test SVCDs on it!!
    I can't find a local dealer who has one, so I am hoping that someone will let me send them an SVCD!
    There is no hidden agenda... I just want to send you a CD which you can play and report back to me.. You can keep the disk afterwards.. I don't want it back...
    The SVCD will be of nothing in particular.. But if you want something.. I could always try and make one up..
    If anyone is willing to help.. Please get back to me, either to the forum, or to '[email protected]'
    Thanks in advance
  2. UrbanTiger
    UrbanTiger
    Email sent, hope it helps :)
  3. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Jon - the DV88 does support SVCD, as it says in the spec. We also tried it out last year on a couple of Chinese SVCDs and IIRC it was fine.
    If you can't get help from the group to evaluate your home made SVCDs I suggest you send one to Arcam Support; provided it is not too long they will tell you what happens. E-mail is [email protected]
    You could also take one along to the dealer you propose to buy the player from and try it out :)
    John Dawson (Arcam)
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,186
    +733
    Thanks all.. Got some voulenteers now.. I will be in touch directly....
    Jon
