Arcam DV88 or HTPC?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Pulsar, Jan 21, 2003.
Tags:
  1. Pulsar
    Pulsar
    Jan 19, 2003
    3,182
    West Midlands - Stourbridge
    +356
    Hello
    I anyone can help me answer the question above, then please help.
    I am looking to add a prog scan projector to my setup, and can't decide on what source to use. I already have a powerful PC, so to make it a HTPC would not cost very much, £200 max. I believe that this would allow me to output a prod scan pictue on NTSC and PAL, and at custom resolutions.
    If I purchased the Arcam, I know that it produces PAL and NTSC prog scan, but am I correct that it would need further equipment to increase the resolution of the picture? I this is correct, what else is needed? I will only be using a relatively cheap projector like the Sanyo Z1.
    All replies appreciated.
    Rob
  2. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
    I have both the Arcam DV88 and a HTPC.
    The DV88 does not do progressive scan, you will need either the DV88P or the DV88+.
    Assuming you get the Progressive Scan version of the DV88 it will not do scaling whereas the HTPC will. The HTPC will also give a better picture quality, at the expense of ease-of-use.
  3. saggio
    saggio
    Dec 14, 2002
    151
    Scotland
    I just changed from a HTPC to the new DV88Plus (that does PAL Prog Scan). IMHO the Arcam is much better, quality and ease of use. I use it with a PIO MXE plasma though, not with a projector.
  4. Pulsar
    Pulsar
    Jan 19, 2003
    3,182
    +356
    Gary,
    Sorry mate, I meant o say the 88+, doh. So what hardware do you have in your HTPC? What cable do you use to connect it to the projector? Would I notice the difference in quality on a 72" projected image from something like the Sanyo Z1?
    Saggio,
    I take your point, but I am deffo looking at a projector.
    Rob
  5. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
    I built my HTPC specifically for DVD playback so it didn't need to have a particularly high spec. It's got a Radeon graphics card, pIII 600 chip 1gb HDD, 64mb ram, M-Audio 24/96 soundcard and a pioneer DVD ROM.
    I'm not familiar with the Sanyo but a quick look at the spec says it's got a resolution of 964x544. If this is correct then you wont need to scale the image so in that respect the output resolution will be the same as a DV88+.
    The bandwidth of a PC graphics card is much higher than the Progressive Scan circuitry in a DVD player so the picture should be sharper and free from ringing. Also PC software players don't suffer from the Chroma bug (Chroma Upsampling Error).
    www.hometheaterhifi.com/volume_8_2/dvd-benchmark-special-report-chroma-bug-4-2001.html
    To use a HTPC the projector will need to have a facility to bypass it's internal de-interlacer to get pixel mapping otherwise the benefit of the HTPC will be lost, I don't know if the Sanyo does this.
    For comparison purposes I use an 84" wide screen with a resolution of 1280/1024 * 764 with my HTPC. I use the DV88 feeding a Faroudja NRS scaler at 1280 * 764. In my system the HTPC has the better picture but I prefer to use the scaler for ease of use.
