Arcam DV88+ or DV89?
Discussion in 'Arcam Owners' Forum' started by grumps, Jun 3, 2004.
Tags:
  1. grumps
    grumps
    May 7, 2004
    156
    28
    +46
    I have recently purchased a Plasma Screen (Panny TH37PE30) with which I am very pleased. However my Toshiba RDxs30 DVD/HDD recorder does not output progressive scan and I feel that now having a progressive plasma I should invest in one that does. I see that Creative audio have some great Arcam bargains, and having an AVR100 and CD72. know the quality of these are both going to be good. Which one should I go for? Is the DV89 worth the extra £100? :lease:
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Get the DV89 if you want DVD-Audio capability. Otherwise, get the DV88+ if DVD-Video is all you need. I don't think there are any other differences.
  3. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    £100 for DVD-A. Makes you think.
    It's a simple choice:
    Watch movies, listen to CD: buy DV88+ :hiya:
    Watch movies, Listen to CD and DVD-A: buy DV89 :thumbsup:
    I have to say that the PQ of the Arcams is much better than the £100 - £300 DVD players that I have seen (IMHO).
  4. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    The DV88+ is superb on my 42" RPTV and i also use it for CD playback now via the analogue outputs.
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Just today I added the SiI504 progressive scan upgrade to my DV88Plus and now it looks even better. :thumbsup:
  6. zAndy1
    zAndy1
    Nov 26, 2002
    22,544
    2
    5
    163
    +8,955
    Yeah but how much did it cost in total? I've just got a Panny TH37PE30 and the Panny DMR-E85 dvd recorder. The nice thing about the dvd recorder is you can set it to output progressive scan for any incoming source signal i.e. I now have Sky in progressive scan just by routing it through the recorder. And believe me it does make a difference! Hope that helps. You get a very nice PAL progressive dvd player , a dvd recorder , decent cd player and the benefit of PAL progressive on sky etc for £500...
    Cheers,
    Andy
  7. grumps
    grumps
    May 7, 2004
    156
    28
    +46
    Thanks for all the feedback guys - one more question though - do you think the CD playback on either the DV88+ or DV89 would be better than my CD72?
    Thanks again
    Grumps
  8. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    go for the dv89 i did, i no your choice in dvd-a is limited but i now have a few discs and find the multi-channel sound worth the £100 extra for the player + the extra phono leads etc
  9. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    Has anyone compared one of these players to the DV79? Was looking to maybe get one but wasn't sure which way to go... I would use it only for movies.
    Thanks guys!
    Rob
  10. hazard
    hazard
    Apr 24, 2002
    137
    Cork
    +3
    Well I have both, and I can't hear any difference between them.
    The only reason I still have the CD72T is just that it's designed to play CDs so it's a little more user friendly.
    I'm talking about very minor details here, e.g. quicker to load a CD than the DV88+, CD text, shuffle & repeat (never bothered to check if the DV88+ has these!)
    Plus, as you can see from my signature, I have become obsessed with collecting black boxes :laugh:
  11. jposner
    jposner
    For what it's worth, I have a DV79 and thought CD performance was a bit lacking, so picked up a 2nd hand CD72T ; it's much better for playing CD's (as you might expect I think)
  12. Sweden
    Sweden
    DV88 Plus audio performance
    In my opinion the DV88 Plus is better as a CD player than an Arcam CD72 (which is a very highly regarded unit, multiple Award winner etc) and not quite as good as the CD82. It is the first DiVA DVD player that I am really happy to use at home as a CD player, which suits my wife as it saves a box on the hi-fi stack.
    John Dawson (Arcam)
