Arcam DV88 (not +), is it worth it?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GavinH, Sep 22, 2003.
Tags:
  1. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    I am in the process of putting together a home cinema set up, and would like some advice about the DVD player. Currently all I have is the amp, the Sony STR-V555ES. I am planning to go for the Acoustic Energy Evo 3B speaker package, and most likely the Toshiba 36ZD26P. The TV choice obviously has a bearing on the DVD player in terms of progressive scan, which, correct me if I am wrong, the Toshiba is only capable of showing an NTCS progressive source…
    The Arcam DV88+ player has not really been an option as it is a little out of my price range. The budget for the system is 3000 (I picked up the amp for 400, which was a pleasing find :).
    However, a friend is selling his Arcam DV88 for 400 pounds, which could be a good option. Yet, based on the time at which he bought the machine, I am assuming that it is the DV88 and not the DV88+. I understand that this means it will not have progressive scan, and most likely will be weaker than the 88+ in other ways too.
    My questions are as follows:
    Is the original DV88 worth the 400, considering newer alternatives, some of which are discounted in shops/on the web?
    Is the DV88+, which I can get hold of for 700 pounds worth it, considering that the TV I am most likely going to get only allows NTSC progressive scan (again, correct me if I am wrong)? Note this would involve me extending the budget :)
    If the TV is going to cost around 1200, the speakers around 760, the amp is already 400, that leaves around 640 for the DVD player and cable – what is a good choice of DVD player?
    Thanks for any help,
    Gav
  2. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    if it were me I would get a tv that accepts both pal and ntsc progresive. I also wouldn't get the dv88 for 400 as you can qutie often find second hand dv88+ for about 650.
    CaM
  3. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Gavin
    I think at £400 the DV88 is a little on the steep side, if you can pick one up for round about the £300 mark and your Display equipment doesnt allow progresive scan, then go for it. Have to say when I've seen a friends DV88 in action the picture was razor sharp, colours and contrast were excellent. :smashin:
  4. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Thanks for the info - do you know whether or not the DV88 provides NTSC progressive scan?
    Also, I have heard that the DV88+ has similar CD replay to the CD72 - is the original DV88 as good?
    Thanks,
    Gav
  5. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    yes, both ntsc and pal progressive. The new dv88+ imo sits somewhere between the cd72 and the cd82. The dv88 sits somewhere behind the cd72.
    hope that helps.
    CaM
  6. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Cam,
    do you mean that its the DV88+ the provides ntsc and pal progressive scan? I thought that the original DV88 did not provide pal prog. scan, but was unsure about NTSC...
    cheers,
    Gav
  7. NedK
    NedK
    Jun 5, 2002
    45
    Fleet, Hants
    +3
    The DV88 definitely does not do PAL or NTSC progressive. The DV88 Plus does both.
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I tested a few DVD players in my system, with some other members of a local forum...
    The original DV88 was better than all the others, except for the FMJ DV27, and the TAG, besides the ones mentioned, we only tested budget players, Sony, Toshiba, Onkyo, Pioneer, Aiwa, Vincent, + some funny brands, up to 500 euros...
