Arcam dv88 I bought one
Discussion in 'Blu-ray & DVD Players & Recorders' started by highlanders, May 22, 2002.
Tags:
  1. highlanders
    highlanders
    Aug 24, 2000
    841
    Manchester, England
    +58
    Well I had a listen today and bought one, see my post "Arcam DV88, Am I wasting my money?" The amp used for the demo was the Arcam AVR200 AV Receiver which I also liked very much so much so I was prepared to have that also. Then the bombshell these newer amps don't cater for laser disks (remember them some people still have them). So it looks like I'm stuck with my yamaha A2 I need the AC3 RF in on the amp unless anyone can help?
    James
  2. robocook
    robocook
    Nov 6, 2001
    137
    19
    Sevenoaks, Kent
    You can get an AC3 RF demodulator which will convert the RF signal from your laserdisc player into a standard Co-Ax or Toshlink digital output which can then be connected to a digital input on the ARCAM.
    Some of them are tiny little boxes a few inches square so easy to hide and forget about. Sony, Yamaha, Kenwood, and even Meridian do/did them.
    Quite a few people have posted wanted in the hardware for sale/wanted forum - could be worth a try.
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
    highlanders,
    I assume you liked it then ;)
    If you want to get the machine totally up to date with firmware etc and find out about a bit more about it try...
    www.envytech.co.uk/dv88
    JJ
  4. highlanders
    highlanders
    Aug 24, 2000
    841
    Manchester, England
    +58
    Yes I did, I already had that link bookmarked that's that got me hooked in the first place. I've just ordered the amp also Arcam AVR200 only thing I didn't like was the remotes Back to reprogramming the RC500.
