Arcam DV79
Discussion in 'Arcam Owners' Forum' started by Oliveira, Jun 16, 2004.
Tags:
  1. Oliveira
    Oliveira
    Hello,
    I´m considering the DV79 to mate with my new Sim2 Domino 20H, using HDMI.
    I´m used to Denon sharp image (i currently own a 2900), and somehow i´ve been induced that usually the Arcams show a softer image than the Denons - i think i´m not in the right place to say this :oops: .
    I was hopping you guys could change my mind! :D
    Is the DV79 Multiregion??
    Thanks for the help.
    Pedro.
    P.S. Is anyone in this forum gonna support Portugal today (i´m Portuguese), since we need all the support we can have!! :clap:
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    I've just got a DV79, and am very impressed with the PQ, don't find it soft at all although I've never seen the pic from a Denon.
    As for multiregion, this can be done from a handset hack which I can't remember of the top of my head :rolleyes:
    John
  3. nikyzf
    nikyzf
    Your Arcam dealer will enable multi-region if you want. It takes only a few seconds.
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    Over the Hill & Far Away
    +137
    1 1 1 1 13 I think..open the drawer, type the numbers close and reboot I believe.. (its been a few years since I set mine)
  5. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    Yup this works have just taken delivery of my DV79 and worked fine for me.... :D
  6. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Got my DV79 and am very happy with the picture quality on my Pioneer 504HDE. However I have two problems -
    1. The player doesnt seem to have the option in its menu system to output component video via its HDMI output even though the instruction manual says it that I can chose between either RGB or Component via its digital video out. At the moment RGB is the only option.
    2. I dont get any Audio on my plasma. The digital out to my processor works fine but no sound whatsoever from the TV. Not sure wht this is about - have fiddled with the audio settings but no joy.
    Any help would be gratefully received.
  7. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Rags, you have a PM.
  8. Oliveira
    Oliveira
    Thanks for your replies...
    Did any of tested it against a Denon????
    Thanks again.
    Pedro
  9. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Thanks - Pioneer are going to come round next week to fix the software bug in the media box.
    Still no joy on the component/rgb problem - I assume component will deliver the better image. Is it part of the same media box software problem ?
  10. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Rags,
    Yes it's the same problem. The media box bug is causing the DV79 to revert to DVI mode, hence no audio or component video, since these are only available in HDMI mode.
  11. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    A Pioneer engineer came round on Friday (very quick response from Pioneer so a thumbs up for them) and swapped out the media box for a new one to which the relevant modifications had been made. I now get the YUV / RGB option but still no sound ! Weird and even he was a bit confused. He's going to come back to have another crack. Not sure how the YUV / RGB problem has been fixed (indicating that the HDMI connection is working) but not the sound ?
    Anyway the picture is very impressive - I definately made the right choice going for the DV79. Does anyone know whether YUV over the HDMI connection is technically better than RGB ? I tried both with progressive scan on and preferred the YUV but am not sure whether there were any real differences or it was just my imagination.
  12. crion
    crion
    Jun 6, 2004
    23
    YUV over HDMI is the non-compromise connection!
  13. nikyzf
    nikyzf
    I can't see any difference between RGB and normal AV into my Sony KV29F1, but S-Video does look sharper. Shouldn't RGB be best, or is it down to the TV?
  14. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    What a great things these forums are, have just checked if I can get YUV over HDMI and I can't. So will be calling Pioneer first thing tomorrow. How long was if from placing the call to them coming to your place Rags?
  15. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Rags,
    You might need to change your audio setting in the DVD player. The Pioneer, like most current HDMI receivers, will only support 2 channel PCM audio, so you need to check the 'audio' setting is '2ch / PCM', to get audio out of the plasma.
    This bit is not 'plug and play', because many people will be using an AV processor and will require bitstream output, when connected to a disaplay that does not support bitstream audio.
    Pete
  16. Gordon @ Convergent AV
    Jul 13, 2000
    14,210
    +3,048
    Hi Mr Engineer,,,,,,
    I want to send a 480i Component signal out of the DV79 to a device that has no edid structure or HDCP. Is this possible (I only want to do this for non encrypted discs.....)
    Gordon
  17. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Now there's a question. Unfortunately the answer is no since the player will revert to DVI mode if a valid version 1.3 EDID is not found (and as you know DVI is progressive scan RGB only).
    The idea of the 'proirity' setting was partly to work around this type of problem, by ignoring the information in the EDID, and allowing it to be overriden. However in its execution the software seems to have departed somehwat from this principle. If you try setting 'priority' to 'analogue' you will find you can set the output to interlaced, but you will still be limited to RGB pixels only.
    I hope this helps
    Pete
  18. Gordon @ Convergent AV
    Jul 13, 2000
    14,210
    +3,048
  19. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Lee - you have PM :)
  20. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Gordon,
    If it sees a 1.3 edid will it then allow the interlaced component out on HDMI?
    It will, provided the edid indicates support for 480i/576i and YUV pixels. Thats basically what the edid is for, it is a way for the display to tell the source what it is able to support. The source is then responsible for making sure it only sends formats that the display is able to understand.
    Pete
  21. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Pete - that worked. Thanks.
