Arcam DV27A and DVD-A
Discussion in 'Arcam Owners' Forum' started by sticker, May 29, 2005.
Tags:
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    I wonder if anyone else has noticed this problem. I was finding that when I put in certain DVD-A discs I couldn't get into the audio set of the disc to select the option of say DVD-A or 2 channel etc. Yesterday I went into the DV27A set up and changed the priority to DVD-A from DVD-V. Straight away I found that I could now access the Audio setup on all my DVD-A discs.
    Anyone else had this?
    Regards
    John
  2. SMCC
    SMCC
    Had that problem once John and now I leave the priority set on DVD-A at all times. It doesn't seem to slow it down when you put a DVD-Video disc in to play so I can't see a downside to leaving like that.
  3. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Hi Stuart
    Yep I've not noticed any appreciable slow down either
    Regards
    John
  4. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    Hi All
    If you have the player set to DVD-V and insert a DVD-A disk then the player reads the DVD-V compatible part of the disc and so does not see the DVD-A part.
    If you want to play DVD-As then you need to have the player set to check for DVD-A first otherwise you will never see the DVD-A part!
    HTH
    Dave
