Arcam DV27
Discussion in 'Arcam Owners' Forum' started by ims, Dec 12, 2003.
Tags:
  1. ims
    ims
    Can anyone tell me to check the firmware of arcam dvd DV27.
    Thanks.
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Look quickly when the machine is turned on as it should appear in the top left hand corner..
    Otherwise if it follows the same pattern of the DV88 then you enter stop, setup, 4, 7, 9, 2
    Matt
