Arcam DV27 zoom function - is it ever enabled?
Discussion in 'Arcam Owners' Forum' started by NicolasB, Nov 17, 2003.
Tags:
  1. NicolasB
    NicolasB
    Oct 3, 2002
    6,436
    Emily's Shop
    +883
    Are there any circumstances under which the Zoom button on the DV27 remote control actually does anything (other than produce the "you can't do that" hand symbol)?
  2. vanwel
    vanwel
    Hmmm, my zoombutton on the remote of the DV88p always works! :S
  3. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    I'll check mine tonight , I thought it worked but haven't used it since going over to a pronto.
    Haven't really found a need for a zoom function
    in the meantime just stop watching the dodgy stuff
  4. vanwel
    vanwel
    I've got a 22" or so 4:3 television. When watching a 1:2.35 movie, the picture tends to get pretty small ;-) Zooming isn't so bad then.
  5. cheeseburger
    cheeseburger
    :clap: Only on certain films does my zoom function work.
  6. Hawklan
    Hawklan
    Oct 20, 2001
    6,742
    Essex
    +312
    I've found that it only works with R1 films
    Give it a try
    RON
  7. vanwel
    vanwel
    My DV88 does it with R2 too.
  8. RossC
    RossC
    Feb 13, 2003
    144
    Never had it work on my DV27 either.
  9. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    tried this tonight on my dv27
    worked on r1 films but not on r2 ones, how strange
  10. danny-p
    danny-p
    I remember that this feature worked on some movies and not on others but after reading some of the above comments and trying myself its true that it will only work with Reg 1?:confused:
