Arcam DV27 Vs 29
Discussion in 'Arcam Owners' Forum' started by niceguy235uk, Sep 15, 2005.
Tags:
  1. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    My local dealer has a 27 on sale for a very reasonable price and i was considering purchasing it but then i remembered about the new (ish) 29. Is the extra money for the 29 worth it? Are there any real differences in quality etc?
    Any passing thoughts appreciated!
    Regards
  2. Hifi addict
    Hifi addict
    go for the DV27 !
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,522
    Edinburgh
    +1,241
    Hmmm, bit of a blunt statement there.
    If you plan to make use of the HDMI output on the DV29 and/or the analogue audio outputs then I would say definitely go for the DV29 if not then go for the DV27A but only if it is a DV27A and not a DV27. If it is not a DV27A the don't bother and get the DV29.
  4. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Hi crusty.
    Why should i go for the 27A? im not bothered about dvd-a so surely the 27 is the same player without the dvd-a??
    Thanks in advance.
  5. Hifi addict
    Hifi addict
    the 27 is definitally better then the 29 in video. and that is the reason why you need a DVD player, right?
    And the difference between a HDMI and component connection is very very minor. Invest in proper cables.
    If you are using it for CD's then it's another discussion but on dvd's.... go for the 27
  6. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    The DV27A has the same processor as the DV29 (the Zoran Vaddis V) where the DV27 has the older Vaddis III. This gives the DV27A somewhat improved video quality and CD playback. It's also more responsive, with a nicer GUI, and has fewer compatibility problems with out-of-spec discs.
    It also, as you say, supports DVD-A playback, and it's capable of producing 5.1 audio output without using an external processor (although you do still need a 5.1-channel pre-amp, and the sound quality isn't as good as a high-end processor would be).
    The DV29 has superior audio and video DACs and the advantage of HDMI output (DV27A is analogue only) but it lacks the onboard Sil 504 deinterlacing chip, so progressive scan output is arguably inferior to the DV27A.
  7. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Agree...the DV27A only uses the Vaddis 5 for decoding MPEG. Deinterlacing is handled by the excellent Silicon Image SiI504, and for that reason makes the DV27A the superior choice if video over component out is of primary importance.
    But all DV27s with progressive out use the SiI. Didn't progressive output appear in the DV27 before the "A" model. If so, any one of those (using the SiI) would be excellent for video, and possibly better than anything Arcam offers new.
    And I question whether the Vaddis 5 deinterlacing over HDMI (DV29) is better than the SiI504 over component (DV27A). I compared my DV88Plus upgraded with the SiI504 against the DV79 with the Vaddis 5 and HDMI. The DV79 using HDMI was not better than my DV88 Plus+SiI over component.
    Dean
  8. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    hi,
    Having the DV29 available at home connected over both 10m HDMI and component to my 5700 projector, I have to say the HDMI is perfection personified :)
    Admittedly this does have something to do with me not spending the time or effort in calibrating the 5700 for component in, or getting it ISF'd. The HDMI is very much a plug and play that produces an absolutely oustanding picture.
    As others have said, and it is my view, if you will utilise the HDMI, go for the DV29. If HDMI is not important, get yourself the good deal on the DV27A.
    Andy
  9. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I have no doubt the HDMI video is better than the component video on the DV29. But they both use the Vaddis 5 for deinterlacing.
    Now to pit the DV29 HDMI with Vaddis 5 deinteracing against the DV27 Component with Silicon Image interlacing would be moe interesting (assuming similar quality of qualibration on monitor inputs). And it would not surprise me to see the DV27 come out better.
  10. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Thanks for all your valued opinions. That has given me serious 'food for thought'.
    Regards
  11. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Personally, regardless of how high I hold the SIL504 in esteme, I prefer a 29 over a 27a over a 27, whether analogue or digital outputs.
  12. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    My DV27 has the Vaddis V processor and it's not a DV27A. It was know as the DV27 plus even though Arcam never offically called it that and filled in before the DV27A was actually launched.
  13. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    Why bother getting any Arcam DVD player, when you own the superior Naim DVD5? (apart from the former being a cosmetic match to the processor/power amp) I have had the Naim player on home demo and have been very impressed. Naim seem to have eradicated the clitches that I have heard about. I don't suppose you fancy an exchange - (DV29 + £?? for DVD5)?
  14. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    But there really isn't any point of telling us that, unless you say why you have that preference. What is it you think is better about the DV29 over the DV27A when using analog video out?
  15. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    It looks better, simple as that, it is a better picture. More 3d....;) Arcam are not daft enough to make a worse player, they are a firm full of bright inteligent people. I think there is allot of points telling people this. In fact I can't think of a single thing that I prefered on the 27, SIL504 included, but it is a player I hold in VERY HIGH ESTEME even now.
    Naim is a great DVD player, but just pop the lids and look how much is the same ;) Did I say that....
  16. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Good point greggles i wondered how long it would take for someone to ask!!! :D
    Well in all honesty im just feeling my way at the mo. The Naim player is absolutley superb in every way, but, i am stiil having a few probs with it.
    ie Takes a long time to load, and various other small niggles that most people wouldnt worry about, but considering its price, i feel the player should work a lot better than it does. My previous player was a dv78 which i thought was fantastic, but, i thought my credit card could do with a hammering and bought the DVD5.
    Im not in anyway Naim bashing at all but i dont feel they spent long enough developing a stable software environment for it. It has no mechanical faults at all, just software. I know dvd is fairly new to Naim and Arcam have been doing it for a long time but if they can sort this out then it will stay on my rack for a very long time.
    My dealer and Naim are on the case but i think i may be losing a little faith. I have just borrowed a CD5X from my dealer to try out this weekend and i think it sounds wonderful, so if it comes to it then i will have that and an Arcam DvD player instead of the DVD5 -maybe-. Its all in my head at the mo so ill have to see what happens.
    Thanks for the offer but my dealer said it will be 'sorted' , one way or the other. Plus the fact you woudnt have the warranty on the unit so future firmware upgrades etc may cost you.
  17. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    If you ask the right people then a swap for a mint DV27a might be an option. Now let me see, who do I know that likes Naim, willing to swap and has a DV27A? Hmmmm..............:)
  18. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    Yes, true. :)
    There are some "DV27" players that have the Vaddis V processor, and, as you say, these are unofficially referred to as "DV27+". However, these are relatively rare. They were made for only a few months while Arcam was struggling to get the DV27A software working. They do not (AFAIK) support DVD-A playback or in-player DD/DTS decoding.
    It is usually better to assume that a DV27 has the Vaddis III processor unless you are specifically told otherwise.
  19. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    It appears that I spoke too soon when I said that Naim had ironed out all the bugs on the DVD5. The one I've had on home demo (with latest firmware) has frozen on me twice while playing back different DVDs, requiring hard restarts on both occasions. The dealer has checked the (very expensive) DVI to HDMI lead that he loaned to me, and it's fine so we are both in the dark?
    The DVD5 also seems to have a worse layer change delay than the DV29, which is not the fastest around.
    CD replay is where the Naim really shines though - far superior to the DV29. I'm returning the DVD5 on Wednesday and am hoping to pick up a CD36 for home demo. Perhaps a one box solution is not the best solution!
  20. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,522
    Edinburgh
    +1,241
    The CD36 is a tremendous machine, I'm sure you will enjoy it.
  21. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    I also think you should give the Naim CD5X a serious listen too (virtually the same price as the CD36 and im borrowing one at the mo). For all the faults on the DVD5, Naim are unbeatable (IMHO) when it comes to 2 channel audio.
    Better still, maybe your dealer might lend you both for an A/B comparison. If he does i would love to hear the results!!!!
    And no, i dont think a one box solution is the best solution.
    Oh, and by the way, what the hell is a PVR? My avr300 had that input on it and i couldnt work out what is w as for!!
  22. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    PVR = Personal Video Recorder, e.g. a hard disk recorder for recording TV, and replacing the ageing VCR. These sort of things
    Andy
  23. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    ooooohhhhhhhhhhhh i see. Ta!
  24. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    I demoed the DVD5, DV29 and the Cyrus DVD8 separately before picking up the DVD5. I haven't regretted it for DVD certainly... the DVD5 is superior in sonic and visual regard and relatively speaking to the DV29 is totally worth the money (well that is before you compare it to a Denon :p ).
    I haven't had too much problems, but then I do spend far more time spinning audio discs than DVD's in general so don't use the DVD5 that often... and that's the rub. I can't believe how crappy the DVD5 is for audio relatively speaking. I say relatively because I realised this only when I got it home. (The Arcam was significantly worse, which I guess fooled me as to the DVD5's abilities) So my dreams of a one-box set-up were dashed yet again.
    But I would buy a Denon 2910/3910 than an Arcam DV29 for sure... unless it's going REALLY cheap. Haven't heard/seen the DV27... but surely it can't be better
  25. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Personally i dont think you will ever find a DVD player that is capable of playing cd's as good as a dedicated cd player, however good the manufacturers say they are.
  26. spark123
    spark123
    Greggles - interesting note. Is the layer change noticeably worse on all discs or just on or two? I'd heard (completely unconfirmed, of course) that the layer change was very good on the DVD5, so would be interesting to hear actual results.
  27. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Personally, dare i say, my previous player, the dv78 was better.
    Not sure about Greggles tho..
  28. spark123
    spark123
    Hmmm. Bit disappointing.
    The one player that I did try, that has almost zero layer change-lag, and region-free out of the box, was the Cambridge Audio Azur 540D. Not quite in the same league, of course, but interesting to see the different implementations at different price-points.
  29. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    It is a bit, but i have been in contact with Naim direct now and they are on the case :thumbsup:
  30. spark123
    spark123
    Do let us know how they respond to the layer change issue you have e.g. is it recognised as a general problem that they can improve upon?
