Arcam DV 88Plus. Tweaks ?
Discussion in 'Arcam Owners' Forum' started by Sweden, Dec 26, 2004.
Tags:
  1. Sweden
    Sweden
    Hi all,
    Does anyone know if i can tweak (and tweaks that works) the cdsound preformance ? Does new feet,ic,spc, new power cord helps ? Or is there a way to tweak it inside to cd93,192 or something like that?
    Mats
  2. robfitzp
    robfitzp
    Dec 12, 2002
    1,162
    38
    Bristol
    +20
    IMHO I would not bother, you would be better looking for a decent used CD player on ebay.
    I have tried using my DV88+ as a CD transport into an external dac and even then it was much poorer than a MF Xray (original version) either stand alone or into the same dac.
    Have also tried a nordost valhalla power cable I had borrowed which livened things uo a bit but nowhere near enough.
    It just is not a very good CD player :(
    Rob
