Arcam Diva Dv88
Discussion in 'Blu-ray & DVD Players & Recorders' started by CARLOS, Feb 11, 2001.
Tags:
  1. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    I have just purchased the ARCAM DIVA DV88
    which I am generally pleased with as regard
    picture and sound .However I have a problem
    in that the sound drops out for maybe half
    a second 5 or 6 times during a movie,I have
    noticed it on a number of discs and it is
    getting rather annoying ,When I play the
    discs on my sony 725 there is no problem.
    I would be interested to know if any one
    else with a DV88 has had similar problems.
  2. Alan Westy
    Alan Westy
    Aug 1, 2000
    Cheshire
    +13
    Carlos,
    I also have experienced drop out but only on DTS films. I have emailed Arcam who have said they are looking into the matter.
    Alan
  3. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    It might not be your dvd player. It might be your amp. the newer dts disc have higher compersion to be able to fit dts and dolby digital on one disc causing sound drop out. on older dts decoders they can not cope so well with the higher compresion
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    Me Too....
    I thought the discs needed cleaning. It does not seem to happen on all discs and I cannot get it to replicate if I replay the same bit.
    Hope its a easily fixed problem!
    Matt
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    Further to my problem the fault happens on DD and DTS discs also if I rewind back the fault repeats in the same place.
    I have also emailed ARCAM and will let you know the outcome .
    The names bueller , ferris bueller
  6. Alan Westy
    Alan Westy
    Aug 1, 2000
    Cheshire
    +13
    Icequake2000
    I doubt if its the amp it does not happen with my Toshiba SD200E which is also connected, and the amp is a Yamaha DSP A1 which should be high end enough to cope
    Alan
  7. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    ALAN
    Snap it seems we have the same taste in amplifiers i`ve also got a DSP A1 maybe there`s something in this !!!
    Carl
    The names bueller...ferris bueller
  8. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Right to join in again I have the Yamaha 795
    I do remeber a prob where on the original DTS Universal DVD's it would drop the sound sometimes due to some flag in the bitstream which the Amps did not know what to do with.. I though this had been sorted as I have not had any probs with DTS soundtracks since Dreamworks and the other studios have been producing them?. Still I hope for a software solution from Arcam.. I would hate to have to return the player.. there does not seem to be much choice at the price (Denon 3300 maybe) and I cannot afford the Tag [​IMG]
    Matt
  9. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    Matt
    Fear not i have just received an email from ARCAM saying they are sending me a software upgrade on a CDR disc which you just play in the machine .
    I will let you know how i get on,fingers crossed !!!!
    Carl
    The names BUELLER...FERRIS BUELLER.
    [This message has been edited by CARLOS (edited 14-02-2001).]
  10. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The latest version of the software for the DV88 is 1.6, though 1.7 should be out soon.
    Rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  11. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    Is there any danger of losing the region hack on the dv88 with the new disc upgrade from arcam
  12. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Excellent.. I await your results.. hopefully I can get them to send me a copy if it works!
    Matt
  13. scissor
    scissor
    I have been running the DV88 with an AV100 amp since last November on V1.3 without any perceivable problems on DVD.
    On CD playback however, when inserting a disc the first second of sound is missing the first time I press play.
    If I press play, stop and then play, there is no problem.
    Has anyone else suffered this ?, is there a software fix ?
    On another note - one reason for buying Arcam was for the service but I notice, from earlier postings, that new software versions are released with no notification from Arcam. Should they not notify all users of updated versions and the bug fixes they contain ?
  14. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Alan.. whay are you switching regions?
    Set the code to 13 and it will autoswitch.. and still work with RCE titles.
    Once yo
    The defaulting of the video output is probably because then regions are set at the factory and it ensured that the video output was correct for the region.
    Matt
  15. Alan Westy
    Alan Westy
    Aug 1, 2000
    Cheshire
    +13
    Matt,
    I did try using code 13 initially, but I am feeding the DV88 to a Quadscan scaler via component output and it will not work with RGB. So what happens is that its ok with a region 1 disc, but when you pop in a region 2 disc the region changes but so does the video out setting to RGB, result scrambled picture with no way of seeing how to alter the setting because the Quadscan can't sync onto the new settings. The only way seems to be to alter the region with the tray open and before closing the tray go into the setup menu and alter the video set up back to component. I think in view of your comments I will have another look at this as I have not tried code 13 since I first got the DV88 and may have not explored all the possibilities and functions.
    Alan
  16. Alan Westy
    Alan Westy
    Aug 1, 2000
    Cheshire
    +13
    From the postings here and my own observations it does seem that while this player offers outstanding video quality it is a bit unpredictable in its operation, other "faults" I have noticed are.
    1. Not able to zoom on all discs
    2. Not able to pause or even stop from the remote some discs.
    Also when changing regions from 1 to 2 for some reason the video output is changed from component to RGB so this has to be re-set via the menu.
    I have been told that this players remote codes operate on a basis of two different codes for each operation, meaning that if you press stop say once and then again two different codes will be sent then the next time the first code will be sent again. This causes problems when coding onto a Pronto although it can be got round.
    All in all while I am more than satisfied with the performance of the unit its implementation does seem to leave a lot to be desired, hopefully rectified with firmware updates. This is probably the price you pay for not buying from a major manufacturer who has the facilities to fully test any machines they send to market in advance. It seems we are being used as beta testers for the DV88
    Alan
  17. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    I have received the update disc and it cured one problem which was the machine not loading an early HDCD disc.
    However the problem with the dropouts is still there so I took my machine back to the dealer who set it up on a YAMAHA amp and we got the same fault , So they tried another DV88 which also had the same dropouts, it seems there is some compatability problem with the DV88 and YAMAHA amps .
    I am sure ARCAM will resolve this shortly and I will let you know the final outcome.
    Carl.
  18. Robert.Fraser
    Robert.Fraser
    Feb 16, 2001
    4
    UK
    I had a couple of problems with my DV88. Firstly there are one or two CDs that it flatly refuses to play. Arcam support have indicated that they are aware of this (way don't they put this on their website) and that a software upgrade will resolve the problem. More worrying, all of the case retaining screws along the back lip of the case were missing. There was some evidence that they had once been in place. I am basically very pleased with the DV88 - but am left very suspicious as to why the case appears to have been opened sometime after manufacture.
  19. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    If you want the software upgrading on your DV88 take it back to your dealer and they will have the update disc. If you can't do this, email Arcam and they will send you a CDR with the new software on.
    Rick
    Home Site: WD A.V.
  20. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Damn I hit post topic not reply!
    Well I spoke to my dealer who didn't know anything about a new software disc. Arcam responded to me via email
    that 1.4 is still the latest version so I guess they have not officialy released the later ones. Shame we cannot
    download the patches and burn our own CD's. To keep returning the player is a pain. but it is better than having
    the player opened for new chips.
    Any further news carlos ?
    One other thing which DTS movies ar causing probs.. I could try and replicate on my setup!
    Matt
  21. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    Matt I don`t have a player at the moment its back at the shop while ARCAM sort out the problem.
    I have even sent them a disc with a list of when the fault occurs, which is T2 SPECIAL EDITION if you have got this disc play the special extended version in DTS and try the times below to see if you have the same problem.
    chapter time
    35 1:08:57
    38 1:14:44
    44 1:22:55
    46 1:28:01
    53 1:49:23
    Let me know how you get on.
    Cheers Carl.
  22. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Carlos.. No problems I will try it out tomorrow.
    Funnily enough I alos got a drop out near the end of Antz (DD Version) so I guess this is not just with DTS Discs.. Ho Hum.. Heres hoping they fix it.
    Out of interest Carlos which dealer did you get the player?
    Matt
  23. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Hmmm..
    Just did a quick test on the first two chapters in your list.. no probs what so ever.
    I find the jumps for me are quite random and I cannot usually get them to repeat if I rewind etc etc.. Maybe you just have a dodgy machine.
    Hmm now where can I find the extra 2 grand to get a Tag Player [​IMG]
    Matt
  24. CARLOS
    CARLOS
    Feb 11, 2001
    6,539
    WEST MIDLANDS
    +1,425
    Matt I also get the drop outs on DD discs,It can`t be the machine as the shop repeated the fault with their DV88 and their Yamaha amp .
    The machine was purchased from sound academy in bloxwich ,west midlands.
    Matt out of interest which Yammy amp do you have.
    Cheers Carl.
  25. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Carlos...
    I have the RV-795 amp bought it about 2 years I think.. it was about 600 quid. It came out just after the DSP-A1.
    This is very confusing [​IMG]
    Let us know if you get a resolution!
    Matt
