Arcam Delta 150 TV Tuner
Discussion in 'Arcam Owners' Forum' started by LostInUK, May 11, 2005.
Tags:
  1. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Hi there,
    After getting a second-hand Arcam Delta 150 TV tuner (I know it sounds strange but it does exactly what I need), I am searching for the Instructions Manual and its remote control or the RC5 codes that I could program on a different controller.
    Unfortunately, it seems Arcam does not have any info or manual about this component anymore.
    Is anybody able to help me with this one? :lease:
    Many thanks.
    Regards
    Pedro
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Pedro
    I can copy the manual (photocopy) for you, re the RC5 codes, not sure but I can post you a remote down to try.
    Great choice by the way, I have 2 :)
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    The nerve of the man, where are my Bad Boys SB discs then :devil:
  5. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Nic: I sent you an email about the discs.(and about some other stuff presumed you hadn't replied as you were busy)....I found BB and another and sent email asking if they were in the box when you got yours or if these were others I'd picked up somewhere.....I presume the answer was that they were not in the boxes I sent.....sorry...
    They are safe here and I'll post them down to you....G
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Cheers, think I read the email but forgot to answer, sorry :) If you post them down that would be great.
  7. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Nick,
    Nice to see you are still around. :hiya:
    I would be very thankful if you could photocopy the manual to me. I will send a PM to discuss details for that.
    About the remote, if I could have it for a while, I could try to get the RC5 out of it. I would then send it to you.
    Thanks a lot for your help. :clap:
    And thanks Gordon for pointing me in the Delta 150 direction. :smashin:
    Best regards
    Pedro
  8. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Nick,
    I have sent you an email through this forum. Thanks.
    Regards
    Pedro
  9. guli
    guli
    Sep 3, 2004
    384
    16
    I was told from a post from John Dawson that it's not RC5 codes but actually Plessy IR codes.
    I have the tuner, remote and manual, but cannot seem to program the remote codes into my learning remote (from my yamaha 750se amp).
    anyone any ideas?
    Thanks in advance,
    Alex
  10. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Hi there,
    Sorry for the delay, but did not spot this message earlier.
    As John explained you, the IR code used with this tunner is not compatible with normal remotes, i.e. the ones that use RC5 code. I had to buy a specific Arcam remote to control mine (I bought the tunner on ebay but it had no remote). So, if your Yamaha remote cannot learn Plessy IR codes, that may explain why you are having problems doing it.
    Regards
  11. pyro2003
    pyro2003
    May 11, 2006
    13
    can someone send me the instruction manual ? I'm trying to decide if I can get one, so need to know remote control support and dimensions -
    i'm at gly2001@netvigator.com
  12. Clem_Dye
    Clem_Dye
    May 8, 2006
    2,484
    +188
    Can't help with an instruction manual, but here's a thought: Arcam, what about making a high quality Freeview box? I remember the Delta 150 and I nearly bought one - in fact I wish I had. Pity.
    Would anyone out there buy an Arcam Freeview receiver? Chuck in some upscaling options for HDMI, component and so forth and I'd be at the front of the queue?
    What do others think? What about it Arcam?
    Clem
  13. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    This was an exceptional product, I have 2 :) but I don't think it was commercially very sucessful for Arcam but certainly a lamdmark product. For me it is one of the few AV 'Classics' and to be treasured. Re an Arcam freeview box, would you buy one at £400 because there is no point Arcam competing at £40?
    Re manual, I know of no electronic copy.
  14. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,608
    Nottingham
    +171
    I had one of these when they first came out and it was fantastic - even better when arcam out an audio digital output on instead of the composite video. The remote was absolutley **** had at least 2 packed up but arcam replaced FOC with a multi function remote that controlled lots of stuff - I have the original instruction book if you want a copy - just pm me with your address I will see if i have any remotes left and let you know if yes
  15. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,608
    Nottingham
    +171
    Sorry just found what i thought was the manual but it is not it is advance product information on back ground and features. :(
  16. MiketheMechanic
    MiketheMechanic
    Dec 7, 2004
    97
    9
    Hi folks,
    sorry to resurrect such an old thread, but I couldn't find the answer anywhere else.
    I looked here:
    Arcam Delta 150 NICAM Stereo Tuner
    and on these forums.
    Does the Arcam Delta 150 TV Tuner have Teletext capability?
    If so, what is/was it like by today's standards? Fast/slow/accepable?
    Thanks,
    MtM
  17. 190evo2
    190evo2
    Feb 1, 2011
    2
    I have a perfect Arcam Delta 150. It's now 2011 and can anybody give me a definitive answer as to whether this product has any use whatsoever in today's world. I'd like to use it if I can and can't bring myself to throw it away.
  18. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,608
    Nottingham
    +171
  19. 190evo2
    190evo2
    Feb 1, 2011
    2
    And does anyone know if it can be used in conjuction with the old Sony Profeel monitor?
  20. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    this issue is are there any analogue transmissions in your area, if there are you can. I have two....no longer used.
  21. spl23
    spl23
    Jan 9, 2004
    2,669
    103
    +385
    Even if it's useful to you now, it definitely won't be in a couple of years with the digital switchover. I'm also not convinced that NICAM would be noticeably better quality than Freeview sound - it certainly won't be as good as Freeview HD with proper Dolby Digital...
  22. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    This device was a true reference in it's day, used by broadcasters. Given a good signal it is a VERY capable device, certainly better than my current freeview...from several sources. It got the best out of the signal rather than playing a numbers game so popular nowdays.
