Arcam CR80 remote
Discussion in 'Arcam Owners' Forum' started by theroohster, May 27, 2004.
Tags:
  1. theroohster
    theroohster
    Is there any way I can programme the Arcam remote to control my SKY+ digibox?
    I've managed to get it to work with most of my other devices, but no joy with the SKY box.
    If not, any plans from Arcam to bring out a fully programmable remote that will work with anything?
  2. BigAl217
    BigAl217
    Apr 4, 2004
    245
    +20
    I got my CR80 to work with my Sky+ v1 box programmed it through learning mode I think or was there a code to set it up cant really remember :confused:
    But it can be done and does work.
  3. theroohster
    theroohster
    Thanks BigAl,
    I shall persevere with it..if only I could remember how to programme it!
    I know it's something to do with pressing the "set" button.....
  4. theroohster
    theroohster
    Nope, cant find the instructions anywhere....
    can anyone tell me the procedure for learning on this remote?
  5. BigAl217
    BigAl217
    Apr 4, 2004
    245
    +20
    Hi Roohster, I've dug out my CR80 guide to learn other remotes set as follows.
    1. Point at each other on flat surface 1 to 2" apart
    2. Press and hold set button on CR80 untill LED blinks twice
    3. Press 975 on keypad (LED blinks twice again)
    4. Press device key on CR80 (ie Sat button)
    5. Press key you wish to teach (LED will flash rapidly)
    6. Press and hold the key you wish to learn on original remote untill LED flashes and stops
    7. Repeat options 5 and 6 to learn other features
    8. To finish press and hold set button til LED blinks twice
    When I did mine some keys I couldnt teach like info and back up so it has never fully replaced my Sky remote but I guess some functionality is better than none.
    Hope that helps :thumbsup:
    Alan
  6. theroohster
    theroohster
    Thanks for the replies...
    followed all the instructions and it still won't work :confused:
  7. BigAl217
    BigAl217
    Apr 4, 2004
    245
    +20
    Hmmm :confused: Works ok with my one maybe drop Arcam a quick email they are normally very helpful [email protected]
    hope they can help.
    Alan
  8. theroohster
    theroohster
    Contacted Arcam support...told them I have lost the manual...
    they very helpfully informed me that there is a list of codes in the back of the manual :rolleyes:
  9. IanDH
    IanDH
  10. SMCC
    SMCC
  11. theroohster
    theroohster
    Thanks Ian, I checked out that link, unfortunately the CR80 wasn't listed...but Arcam support have mailed me one in PDF format :0)
  12. Roohster
    Roohster
    Jul 1, 2004
    4,253
    7
    Derbyshire
    +4,691
    Well, I got the manual, tried everything, and I still cant get the thing to operate my SKY+ box (or my panny plasma if it comes to that....)
    By the way, I now have a new identity on here as my old "Theroohster" account went awol...
  13. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    Any joy to date on this little dilema?
    The CR80 looks like a straight forward remote to do 'most' functions of all other remotes and kit.
  14. Roohster
    Roohster
    Jul 1, 2004
    4,253
    7
    Derbyshire
    +4,691
    No joy...
    everyone says it should be able to learn the SKY+ codes, but the plain fact is, it won't! :(
  15. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    Unfortunate. I really didn't think Sky+ or otherwise would be so unique as to be unlearnable.
    Has the remote learnt everything else it's been taught ok?
  16. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    Another possibility is that the remote's memory is full, which happens sooner than you may think. If when trying to teach the remote a command the LED just blinks once then it usually means that the internal memory is full. Try deleting a few other learned commands that you don't need as much and have another go learning the Sky commands. I had this problem with my MF amp remote commands and so I deleted all the number buttons I'd learned from the Sky remote and now everything works. The only thing I can't do now is manually punch in a Sky channel number.
  17. Roohster
    Roohster
    Jul 1, 2004
    4,253
    7
    Derbyshire
    +4,691
    Nope, tried that too...in fact I deleted everything I could think of, so that the remote was just left with the arcam codes for the amp and dvd.
    The damn thing must be nearly "empty" and it STILL won't learn and new codes!
  18. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    Bash it. :)
  19. Roohster
    Roohster
    Jul 1, 2004
    4,253
    7
    Derbyshire
    +4,691
    I've tried bashing it, talking to it nicely, swearing, buying it flowers...
  20. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    Are sure you followed the deletion process correctly? You need to press the button you wish to delete twice in order to erase it's memory. I made this mistake the forst time. Apologies in advance if you have already tried this.
  21. Roohster
    Roohster
    Jul 1, 2004
    4,253
    7
    Derbyshire
    +4,691
    yup,
    pressed twice and got two led flashes in confirmation.
    Might try new batteries - probably won't help, but I'm out of ideas now...
