Arcam CR80 remote and Telewest DI4000
Discussion in 'Cable TV & Virgin Media TV' started by matthew_hallson, Oct 5, 2004.
Tags:
  1. matthew_hallson
    matthew_hallson
    Hi...
    I have a new Arcam AVR300 which is pretty good and telewest, which is being delivered by the Scientific Atlanta di4000 box...
    I have been able to get the CR80 to control most of my it, however not the di4000 - I have tried all the manufacturer codes for sciatl in the manual however no luck with these, and all it seems to be able to learn is power off (not on), and nothing else.
    Has anyone else with this remote and telewest had any luck?
    Regards,
    Matt
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I believe Telewest uses IRDA codes which cannot be learnt by most learning remotes.
