ARCAM CD93 to AV32R Connection Query
Discussion in 'TAG McLaren Audio Owners' Forum' started by scarty16, Jan 5, 2005.
Tags:
  1. scarty16
    scarty16
    Jul 1, 2003
    1,058
    +97
    I have just stolen an Arcam CD93 from Sevenoaks (their words not mine!!) via ebay and now I am wondering what connection I should go for into the AV32R SP 96DACS.
    I have currently used the digital co-ax with a QED cable, but would the phono's be better due to the 192DACS that the Arcam has.
    Thanks in advance for the advice.
    TTFN
    Simon
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Hiya.
    All the analogue inputs on the AV32R are digitised, processed then returned to analogue using in your case the 96Khz ADC/DAC's.......(apart from the 5.1 bypass maybe which you haven't got?). The digital output on the CD93 to the digital input on the AV32R then???
