arcam cd82t - upgrade opinion ?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by mackenz, Dec 10, 2004.
Tags:
  1. mackenz
    mackenz
    Alpha 5 - Audiolab 8000 - Mission 753
    Low useage
    Recently bought 2nd hand Diva CD82T
    Any opinion on imporovement I will get over the Alpha 5
    Are the amp & speakers adequate or should I consider upgrade also ?
  2. Paulholio
    Paulholio
    I found a big improvement on the 82. I'd maybe look at getting some Dynaudio speakers. The amp in its day was superb. Depending on how much money you wanna spend there are so many amps available. I recently had a demo at frank harvey with the cd192, a90 and dyn 52se.
    Gets a thumbs up from me :thumbsup:
