bass007
Hi, I'm thinking of replacing my Pioneer LX-87 with one of the above. Reason for upgrade is simply after reading about the wonders of the Dirac room correction has given me upgrade bug.
Now I will ONLY be using it as a processor, what are the main differences ? is it just the power amplifier section of each model, or are is there other improvements to the processing section the further up the models you go ?
I do not have a dedicated room, I'm looking to get a decent, worthwhile upgrade from what I have, its only going to be used for movies NO music.
While I appreciate there is a significant price difference between the AVR receivers and AV860 processor I cannot find any other information on the Arcam website, the main differences are I can see according to the website are in the power section.
