Arcam AVR390 power amp options?
SonicHedgehog
Very happy with my new AVR390 so this may be a hypothetical thread depending on cost.
I have a pair of MA GS20 fronts, a GS centre and two MA ceiling speakers and a BK XLS400 sub. I also have a Quad 909 power amp that I used with my old AV amp to power the GS20s. As I understand it I cannot use the Quad with my Arcam in the same way. All five channels need external amplification. Or do they? Is there a clever way to wire this up to make use of the Quad?
If the answer is no I could sell the Quad for about £500 and buy a five channel power amp. Max budget would be £1000 for that amp which might be tight given the quality required to improve on the AVR390 and I wouldn’t want to go too old for fear of reliability problems. Or I could keep the 909 and get a couple of used 99 power amps to power the centre and ceiling speakers.
Come on boffins, let’s work this one out!
D
Deleted member 39241
You can use your quad. All pre-outs are live all the time just cable up the pre-outs from the channels you want to add external amplification to. You can do as many or as few as you like.
SonicHedgehog
Mmm...I read a review that said its either all or nothing. i.e. You have to have an external amp for every channel. Is this not the case?
D
No, it is definitely not the case :)
There is a restriction in that if you are using power amps for the 7 main channels, you cannot then re-assign those channels to be height speakers.
But for a 5.1 set-up, you can use any combination of internal or external amplification.
