B Buckster Distinguished Member Joined May 21, 2001 Messages 7,322 Reaction score 383 Points 1,475 Location UK Oct 27, 2008 #1 please confirm whether it does or not - I suspect so - but manual just says bass management is not available when using multichannel in thanks, Mark.
Druboo Established Member Joined Apr 1, 2006 Messages 882 Reaction score 130 Points 155 Location Cotswolds Oct 27, 2008 #2 Correct .... Needs to be set in the source Only thing set in the AVR that applies to m-ch is the speaker trim levels.
B Buckster Distinguished Member Joined May 21, 2001 Messages 7,322 Reaction score 383 Points 1,475 Location UK Oct 27, 2008 #3 thanks - thought so - just checking means getting the likes of a EP-35 HD-DVD player is pointless for using analogue audio in as it only does levels not delays
M markusp Established Member Joined Jul 21, 2005 Messages 326 Reaction score 26 Points 61 Oct 27, 2008 #4 Druboo said: Correct .... Needs to be set in the source Only thing set in the AVR that applies to m-ch is the speaker trim levels. Click to expand... Are you sure that trim levels are still applied in the m-ch mode? I thought this was strictly a bypass and as a result, nothing applies aside from a user being able to adjust volume.
Mark.Yudkin Distinguished Member Joined Sep 19, 2007 Messages 11,475 Reaction score 2,182 Points 1,886 Location Zurich, CH Oct 28, 2008 #5 Druboo is correct. Trims are applied, but nothing else. (Trims are a per-channel volume control - a generalization of the stereo balance control).
