arcam avr300 speaker impedance setting
zamwessell
i am using 2 monitor audio GR.20 (6 ohm), 4 M&K K-4 (4 ohm ) and a Ruark Dialogue One ( 8 ohm ).
The set up on the Arcam AVR300 tells you to set the impedance setting to 4 ohm ( Speakers 6 ohm or lower ) or 8 ohm.
If i set it to 4 ohm will it be ok.
Thanks.
buns
Yup..... setting to 4 ohms will have no issues with higher impedence..... using low impedence speakers with the 8 ohm switch is the worry as far as damage is concerned
ad
