Arcam AVR300 not playing dts
Discussion in 'AV Receivers & Amplifiers' started by billmag, Jan 20, 2008.
Tags:
  1. billmag
    billmag
    Sep 14, 2006
    76
    alloa
    I have changed my 7/1 set up back to 5/1 and find that,when playing dts es discs,my av 300 will not switch to dts 5/1 but standard dts discs switch ok.Has anyone noticed this? I am using speaker 6&7 output to bi-amp front speakers.
  2. blue max
    blue max
    Apr 12, 2006
    12,938
    London
    +4,308
    I think you need to go through all the setup options. I think there is a menu where you can specify how the amp handles dts es.
    Hope it helps you sort it out.
    Graham
  3. billmag
    billmag
    Sep 14, 2006
    76
    alloa
    Cant see anything in menu or instructions! Can you be more specific?
  4. ianmacd
    ianmacd
    Jul 5, 2007
    1,013
    48
    +80
    I believe Blue Max 2 is referring to setup menu page 6. See what that is set to. Mine says "Auto". Have you got some example disks as I will look too if I have them.
    Thanks.
    Ian.
  5. Playitloud
    Playitloud
    Jun 4, 2004
    88
    11
    Chelmsford
    +4
    Hello Billmag,
    If memory serves me right I think your problem could be software related.
    Do you know what software version your AVR300 is running (hold the buttons SAT and DVD at the same time and it was display the version on the from panel). This may hold your answer.
  6. billmag
    billmag
    Sep 14, 2006
    76
    alloa
    Thanks for info Ihave checked ex setting set to manual will try auto.Also looked at software and it reads 300-2.84 followed by dsp 1.12 It seems that all the discs I have encoded dts ex. wont switch to dts.Will try auto when granddaughter stops watching tom&jerry!
  7. Buff99
    Buff99
    Aug 23, 2005
    55
    Edinburgh
    +10
    That firmware had exactly that bug with DTS/ES when bi-amping... doesn't occur in 7.1
    upgrade your firmware to fix this.
    The current release notes upped by Crusty start at 2.90 so you won't see this change.
  8. Playitloud
    Playitloud
    Jun 4, 2004
    88
    11
    Chelmsford
    +4
    Based on software version 2.84 I would hedge my bets that an update will cure your problem. I am sure there was a fix for this bug in the high 2.?? firmware updates.
    Tom & Jerry in DTS could be interesting :)
