Arcam AVR300 Help!!
Discussion in 'Arcam Owners' Forum' started by remdog, Apr 29, 2005.
Tags:
  1. remdog
    remdog
    I'm having a problem with my ARCAM passing through the hi-def signal from a Scientific Atlanta HD8300 PVR. This PVR is a replacement for the HD8000 model that won't power up anymore.
    The problem is that the video signal is over saturating the colours. If I bi-pass the Arcam the signal is fine.
    I don't know if it's an issue with the newer model of the Scientific Atlanta hi-dif PVR or not. I'm not sure if maybe I should try to find another HD8000 PVR like the one that died.
    :lease: :lease:
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    Best leave this one too John Dawson or Andy Dutton I think.
