Arcam AVR300 HELP!!!
Discussion in 'AV Receivers & Amplifiers' started by remdog, Apr 29, 2005.
Tags:
  1. remdog
    remdog
    I'm having a problem with my ARCAM passing through the hi-def signal from a Scientific Atlanta HD8300 PVR. This PVR is a replacement for the HD8000 model that won't power up anymore.
    The problem is that the video signal is over saturating the colours. If I bi-pass the Arcam the signal is fine.
    I don't know if it's an issue with the newer model of the Scientific Atlanta hi-dif PVR or not. I'm not sure if maybe I should try to find another HD8000 PVR like the one that died.
    :lease: :lease:
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    I don't have a specific answer to your query, but you maybe better of asking the question in the dedicated Arcam forum further down the main page. Lots of very knowledgable people there and several representative from Arcam.
    http://www.avforums.com/forums/forumdisplay.php?f=119
