ARCAM AVR300 driving Capacitive Loads
Discussion in 'Cables & Switches' started by hamiltod, Feb 1, 2005.
Tags:
  1. hamiltod
    hamiltod
    I will be using Arcam AVR300 to drive my Spendor Audio speakers (impedance 8 ohm) I am looking to use speaker wires from wireworld Solstice 5 with bare wire termination. I will bi-wire the front LR. This is a symmetricoax speaker wiresand they say these wires should not be used with certain amplifiers that are unstable with capacitive loads. Will these speaker wires work with my AVR300
    Thanks for prompt reply
  2. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    Suggest you ask on the ARCAM forum - or e-mail Arcam tech support.
  3. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    The AVR300 is stable into capacitive loads so there should not be a problem.
    John Dawson (Arcam)
