Arcam AVR200 with component in/out?
Discussion in 'AV Receivers & Amplifiers' started by [email protected], Jan 22, 2002.
Tags:
  1. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    Looking to upgrade my kit in the near future. I'd really like to go for the Arcam AVR200, but I think I will need component video switching to drive either a plasma screen or a projector. Anyone know if Arcam are planning a successor to the AVR200 which includes component inputs/ouput?
    Regards
    Rob
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I wouldn't expect a new version of the AVR200 for at leats another year, as they are busy finishing their new AV8, which does have component switching, amongst others.
    What do you need to switch from/to?
  3. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Switching DVD and Playstation initially, and perhaps using the component inputs to switch RGB from a digital box at some stage in the future (does anyone know if it is possible to convert RGB scart output to compnent phono/bnc?).
    Regards
    Rob
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    It certainly is possible to 'transcode' RGBS to component YUV. You will need (currently) a box from either Kramer (prro standard ans expensive) or Digital summit (Ask Gordon he's getting one). JS technologies are due to bring one to market soon though which should be good and cheaper, and easier to use as it will take a direct RGBS SCARt connection rather than RGBS on BNC's.
    For other external switching you could try a Kramer box though as this wouldn't be too expensive.
  5. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Thanks. John Sim's convertor sounds like it might be closer to my budget. All I need to do now is decide which amp.
    Regards
    Rob
